Budget FTW Build
http://pcpartpicker.com/p/nJfq
There is the build I want to build during the holidays
Any suggestions?
Here are the specs for those too lazy to click a url (like meh)
CPU: Amd fx 6300
Mobo: MSI 970A-G46 ATX AM3+ Motherboard
Memory: Intel Extreme Masters Ram 2x4
Storage: scavenged 400 gig 7200 rpm drive
Video Card (my fav. part): EVGA gtx 670 FTW
Case: Rosewill Redbone
PS: Corsair Builder 500w
Budget NO MORE THAN 700!
LEAVE CONSTRUCTIVE FEEDBACK BELOW PLZ
Ty broskys ha
I dont need os or keyboard or mouse
Try to budget in an SSD somehow, one just big enough for at least your OS.
If you want to save some cash I suggest the 7950 overclocked it easily competes with 670 and sometimes, if you are lucky, the 680.
You are also going to need a better psu and mobo if you want to push your system to the max.
Heres something that might suit you better: http://pcpartpicker.com/p/nLnu
Hmm dont really want to go above 700 bucks. Ill mess around after school with it.
