I'm in much help with building a new budget PC, I'm looking to stay in the $1000-$1200 (thats with peripherals). I've tried my best to build on a budget but it just doesn't work. This would aslo be my first build so I'm was looking for a motherboard with an updated or can i say "more up-to-date" BIOS. This will also be needed to play some powerful games so a great graphics card would be nice. I also don't plan on updating my PC for a while (1-2 years) so hopeful that will help you help me. I will be running Adobe Premiere Pro and maybe some Photoshop. Any and all advice would help.
Do you need any peripherals, or an OS ?
EDIT: just saw you need peripherals too. Mouse and / or keyboard and / or monitor ?
You will be hard pressed to find a build that is tougher than this. (I would call this a 5+ year rig)
Total ......... $1132.00
PCPartPicker part list: http://pcpartpicker.com/p/FtCZWZ
- CPU: AMD FX-9590 4.7GHz 8-Core OEM/Tray Processor ($239.99 @ Newegg)
- CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($71.20 @ Amazon)
- Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+($114.99 @ Newegg)
- Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 ($166.99 @ Newegg)
- Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($86.21 @ Amazon)
- Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM($56.98 @ OutletPC)
- Video Card: Gigabyte Radeon R9 285 2GB WINDFORCE 2X($249.99 @ NCIX US)
- Case: Fractal Design Define R4 Blackout ATX Mid Towe($79.99 @ Newegg)
- Power Supply: XFX ProSeries 750W 80+ Gold Certified($89.99 @ NCIX US)
- If you need every thing ...
- OS - keyboard - mouse - monitors and such ...
- we would have to water this down quite a bit.
- But it should be do-able .
My take on it
http://pcpartpicker.com/user/Tudor/saved/kkXV3C OR http://pcpartpicker.com/user/Tudor/saved/kGqrxr
- CPU - intel Xeon 1231 V3
- GPU - EVGA GTX 770 ACX SC or XFX R9 290 Double disipation
- RAM - G.Skill Ripjaws 2 x 4 GB
- Mother Board - Asus H97 plus
- SSD - Crucial MX100 128 GB
- HDD - WD Caviar Blue 1TB
- Optical drive - LG Blu-Ray writer
- PSU - Corsair CX600m semi modular
- Case- Corsair 200R
Well yes, make sure we add the OS, monitor, keyboard, and mouse to it... But I am loving these builds, their awesome
Yep, we do need to water this down... though may I say, awesome build, but question, don't nvidia GPUs have more cuda cores, you know for Adobe....
Small boo boo with those two coolers.
More cores != better when comparing completely different GPU architectures.
Adobe has worked in pretty good OpenCL acceleration now, making CUDA not as amazing as it once was.
http://pcpartpicker.com/p/HFxxTW
Xeon E3-1230 V3 (Didn't go with the E3-1231 V3 in case of UEFI compatibility issues)
16GB of RAM
R9 280
Periphs included
$1,120
buy a cheap $20 or less keyboard/mouse combo by Logitec. That will more than tide you over until you get fancy with peripherals. Spend your money on cpu/gpu and other key components.
Be sure to check what will benefit you most, CUDA (nvidia) or OpenCL (AMD). The latest Adobe Premiere and Photoshop support both CUDA and OpenCL hardware acceleration. I don't know which one is faster / more efficient though.
http://pcpartpicker.com/user/Tudor/saved/vntLrH (GTX 760) or http://pcpartpicker.com/user/Tudor/saved/gwcgXL (R9 280)
- OS - Windows 8.1
- GPU - GTX 760 or R9 280
- PSU - Corsair CX500
- Monitor - Asus 23.8" IPS
- Mouse - Gigabyte GM-M6900
- Keyboard - Gigabyte Force K3
(Peripherals are a matter of prefference. I went with the reasonably priced well rated ones)
Or as Relinquis said, go with a cheap keyboard and mouse combo and get some more RAM.
very capable rigs But a little short on ram
- Op should try the local thrift store like Goodwill or Value Village and get ...
- USB keyboard (I like the Dell keyboards with multimedia controls $5 )
- optical mouse ( Logitech or Microsoft optical USB mouse $5 )
- second monitor (will help with productivity) I got a 22" LG for $20
- third monitor?
- speakers?
Dang gotta give it to the tek syndicate support. YOU GUYS ROCK
yes sensei ... i will try harder next time ... (palms together ... deep bow)
Here Sensei ... this will appeal to OP
http://pcpartpicker.com/p/myDQwP
- Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor
- MSI B85M-P33 Micro ATX LGA1150 mobo
- A-Data XPG V2 16GB (2 x 8GB) DDR3-1866
- A-Data Premier SP610 128GB 2.5" SSD
- Seagate Barracuda 1TB 3.5" 7200RPM HDD
- Powercolor Radeon R9 280 3GB TurboDuo
- BitFenix Merc Beta (Black) ATX Mid Tower
- Corsair Builder 600W 80+ Bronze Certified
- Microsoft Windows 8.1 - 64-bit
- Monitor 1: AOC I2269VW 60Hz 21.5" Monitor
- Monitor 2: AOC I2269VW 60Hz 21.5" Monitor
- CM Storm Devastator Gaming Keyboard w/Optical Mouse
- Total including shipping .................. $1231.20
Estimated Wattage ....................... 403W
Or have it with CUDA Cores if you want .........
PNY GeForce GTX 760 2GB Enthusiast Edition Video Card
(for $23.89 more)
http://pcpartpicker.com/part/pny-video-card-vcggtx7602xpb
I Love You Guys SOOO much, I've been on console gaming for so long, and console gaming communities aren't as easily helpful and nice. I must say, the Tek Syndicate Community is awesome. I forgot who's build in thought was awesome, but honestly, you guys are amazing. Your incredible and I truly appreciate it guys
