Budget case + window
hi guys
just a quick question, does someone knows a good quality case + window atx standard.
280x toxic is 308mm.
was thinking about a nzxt 410 elite but it isn't availble and when it is it's like €100, $130
my budged is €50, about 65$ but if you need it can be a little higher.
i live in the Netherlands btw
I'm not sure what it is in eu but I have the Bitfenix Shinobi window white and i love it. http://www.bitfenix.com/global/en/products/chassis/shinobi#gallery
It has good airflow, style, space and cable tie downs for cable management in the back. But it's doesn't have rubber gromets for cable management (mostly for style) or dedicated ssd mounts. Otherwise i really like it.
I comes with blue accents but they're easily spray painted.
I dressed mine up with red LEDs too.
