Hi Guys
I've got a new Asus M5A97 mobo and AMD 6300 CPU. Can someone give any advice as to a good budget case.
Looking for the usual features, good airflow, easy cable management, USB 3.0 and quiet.
I've seen the Fractal 1000, which is about £30 in the UK, but is there anything better I am missing out on?
All ideas welcome.
If you want some thing cheap i would go for the nxzt source 210 its a bit boring but has good quality and is a solid case it you are on a budget.
http://www.scan.co.uk/products/nzxt-source-210-elite-black-mid-tower-gaming-case-with-usb-30-w-o-psu
I agree, a nice solid case for the price!
looks good - is there space behind the motherboard tray for cable mgt?
how does it compare to the Fractal 1000?
with the fractal core 1000, you will save £10 but will just lose great features such as USB3.0, will have less drive bays and other things like have a smaller case fan included compared to the NZXT's 140mm. you will lose some build quality but its £28 compared to £38. your choice bud!
You cant use a Fractal core 1000 as its a micro ATX case and your Asus M5A97 mobo is ATX. (your mobo is too large to fit in the case)
(ATX)Cases around the £30-40 mark with front usb 3.0 ports.
Zalman Z5 Plus
NZXT Source 210 Elite (Black)
NZXT Source 210 Elite (White)
Silverstone SST-RL01B-USB 3.0 (Black)
