Gotcha. Seems like an interesting way to “fine tune” your own fan speeds.
Seems a little self-promoty for your website/company …
Arctic and Sycthe
Some arctic fans can be had, in bulk [5ct.] packages
I agree, the Arcic fans that come in Five-packs are are very hard to beat for the money.
If you can buy Sunon Vapo, those are worth the trouble IMHO. But they mostly have smaller fans, don’t think they come in sizes larger than 120.
Fractal Design Silent Series is also good for the money. I have few 120 versions and they have performed well enough.
R2 - yes, but they don’t push a lot of air…
R3 - noisy compared to R2…
The new Venturis and what not - expensive…
I have no experience with the original Silent Series, but I have a bunch of the others…
Check out Thermalright (Chinese comapany).
They are competing with Noctua, and are cheaper. I still go with Noctua for coolers, but I have two Thermalright fans (and one in the box) as front fans for my Meshify C. They compare favorably for this task.
They have a good variety of products on Amazon.
I’m in this post and I like it…
In the past I would buy whatever budget fan that was on sale at Microcenter, as long as you read the specs you could find a budget fan which matched the performance of an Antec fan which I often used as a baseline. Scythe is the most silent of fan makers, however their fan choices changed a bit. As fans have gotten better, there really isn’t any excuse not to buy an Arctic fan in their 5 pack since the airflow to speed ratio is extremely good if you’re trying to build a near silent PC.
As far as name brand budget fans, Coolermaster 80mm fans in my experience in mATX usage have lasted the longest. Coolermaster Blade Master 120 in my opinion replaced Antec for the baseline fan.
