Hello I am really not good with chipsets and yadda yadda am I even on the right track look at these part and correct me if I'm off on anything because I don't want put it together and it doesn't start or starts burning .
here the part that i picked out.
1 xGigabyte GA-F2A88XM-HD3
1 xAMD A10 5800K 3.8GHZ BLACK
1 xCoolerMaster Elite 310 Silver / Black
1 xCorsair Vengeance 8GB 1600MHz
1 xCorsair Builder Series CX 430 W
I will by a GPU when I have funds for it.
Will they work together or is it something i missed please comment and correct if needed
You should do two things, upgrade to the A10-7500k, a huge price per dollar difference. Get faster ram such as 2133 mhz (your motheboard supports it) spending 20 extra dollars on faster ram will give you a noticeable performance increase. Other than that it looks great! no incompatibility issues. just add in a hard drive and the other necessary stuff and your set to go!
This is your best bet. With the low cost GPUs it really doesn't make much sense to go the APU route to me for gaming.
This setup will give you better performance and the Athlon, while not a great CPU, does fine in most games which means you'll just need to throw in a new GPU if you want better performance later on down the line.
