Budget Build ($400)
Here is my budget build
CPU: http://www.amazon.com/AMD-FD6300WMHKBOX-FX-6300-Processor-Edition/dp/B009O7YORK/ref=sr_1_1?ie=UTF8&qid=1385712192&sr=8-1&keywords=amd+6+core
MoBo: http://www.amazon.com/Asus-M4A89GTD-PRO-USB3-Motherboard/dp/B003964KK8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1385712355&sr=1-1&keywords=AMD+3.2+Hz+Phenom+II+X6
CPU Cooler: http://www.amazon.com/Cooler-Master-Hyper-Plus-RR-B10-212P-G1/dp/B002G1YPH0/ref=sr_1_9?s=electronics&ie=UTF8&qid=1385872223&sr=1-9&keywords=corsair+h50
GFX Card: http://www.amazon.com/XFX-FX777AZNF4-1000MHz-miniDP-Graphics/dp/B007A44T42/ref=sr_1_2?s=electronics&ie=UTF8&qid=1385874469&sr=1-2&keywords=radeon+7770
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820313102
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811233073&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I just want to know if I can get the same thing cheaper anywhere else, or if I can get something better for less money.
PS: I bought the motherboard and CPU bundled for 100 bucks, and I have already bought the case, so those things cant change
i would suggest getting a single 4GB stick of ram now and then buying another 4gb stick once prices come down.  if you got the money, get a 2x4GB kit now.
As Highroller said, Go for a single 4GB stick (or single 8GB if you have more money to splurge). This is purely for upgradeability. In the future if you want more ram (say between 8 and 16GB) you'll need to dump those 2GB Sticks. The more GB of ram in a single dimm, the more you can add later.
As your mobo has 4 ram slots
2GB sticks: Max of 8GB
4GB sticks: Max of 16GB
8GB Sticks Max of 32GB
 For that reason I'd recommend a 4 or 8 gig stick.
 single 4GB Stick ($35): http://www.newegg.com/Product/Product.aspx?Item=N82E16820104261
single 8GB Stick ($60): http://www.newegg.com/Product/Product.aspx?Item=N82E16820148540
why such a beastly mobo on a $400 build?
Get a 970 mobo instead of this one and add the difference to the gpu and get a 7870.
