I'd like to request a guide for installing btrfs-scrub .
I've downloaded the source and installed the theoretical dependencies but I keep getting errors.
This is where I got it.
https://launchpad.net/ubuntu/+source/btrfs-tools/3.17-1.1
Is there any reason you wouldn't just install it from the repo?
I couldn't find a repo
sudo apt-get install btrfs-tools
I have that you have to have that to format to btrfs btrfs-scrub doesn't come with it.
nvm
Were you able to fix the issue?
yeah it was in an update
