BSOD memmory error help
Ive been getting BSOD at random intervals.  it happens mostly during high intense gaming. I swept and reinstalled my nvidia drivers. i ran memtest86 with all of my 4x8 32GB of RAM and got this https://www.dropbox.com/s/iz9ci7pqo27n8po/20130723_022950.jpg Ive ran each stick individuallyu and they all passed so im confused.
It all depends on how old the video card is the life span on a card is average 2-3 years on hardcore gaming try switching out the card with an older video card you have lying around see if you get the bsod. If you are like me having computer parts lying around you can pretty much diagnose any problem. If the video card is not the problem then switch the power supply  since it usually happens while gaming. Thats my lucky guess.
my viseo card is about 8 months old and same for my psu. there both good ones
I was looking for your old thread and found this one. Take out a stick of ram and play around and try to force the BSOD. If it happens, replace it and take out another. If you do that for all sticks and you still get issues let us know.
ok ill try that
Try taking the GPU out and running your PC under high load. It might be a faulty GPU.
