BSOD errors
Hello,
I have just finished my new pc and I keep getting BSOD errors while doing anything.
MEMORY_MANAGEMENT
QUOTA_UNDERFLOW
NTFS_FILE_SYSTEM
I was reading online that some of these errors can be caused by faulty memory so I ran Memtest86 for 9 hours and it said test completed 48 tests passed with no errors.
Does this mean that memory is not the problem?
Any ideas what I should do next?
PC specs
http://uk.pcpartpicker.com/p/ZbPWgs
Many Thanks
Did you try running with just a single Dimm of Ram at a time, see if any manage to play nice when alone? I'd also run a disk check. If you have a spare power supply, try it, also a quick SFC /SCANNOW couldn't hurt.
