I'm sure this is illegal and wrong and immoral, but I don't really care. My friend got a new router and thinks he is high and mighty and hack proof.
I want to prove him wrong.
I think people call it being a 'white hat' to prove someone there are holes in their security, and prove to him once and for all that no security is perfect and he needs to come down off of his high horse. Bearing that in mind, I believe the most straight forward means of doing this is to do a 'brute force' attack where the computer just guesses blindly until success. But I'm new to this and don't really know where to start, is there anyone who can give me some advice? Just to make sure I don't accidentally do any permanent damage.
It's not illegal so long as he gives you consent. Of course, you'll need to make sure you have tangible proof of this consent on hand just in case he were to attempt to take you to court or have you arrested.
Very important words, but as long as your friends aren't uptight pricks I wouldn't see the issue regardless. Then again, with the sue happy world we live in today you never know.
Regardless, Backtrack 5 was stated and is a great tool that should work perfectly for your application here.
Whether you can hack his wireless or not and how depends on how it is set up. Is he using WEP? It is flawed and easily hackable. What about WPS? It too is flawed and easily hackable. Is he using only WPA2? If so, it's still possible, but it's going to come down to the strength of his pre shared key (password).
Check out this video series, and definitely get his consent before trying to hack his shit.
Before you dive into attempting to remotely mess with his router, how easy would it be for you to look up the default admin password and then go hit the reset switch? I guess I'm trying to say showing him his security is not perfect might not involve getting his password, if you have access to the hardware ....
