A buddy of mine broke the ID pin off of his Motherboard USB 3.0 header. Diagram What does this pin do? Is there an easy way to fix it? If he just leaves it broken with nothing plugged in will it cause any other issues?
The pin broke off at the base so it is flush with the plastic. He plugged the USB 3.0 in and noticed it wouldn't go in all the way pulled the plug out and noticed it was broken off. He has not tried it out of fear of damaging something else.
Thanks!
Its supposed to be for over current protection. If you have a soldering iron with a very fine tip you could attempt a repair.
I wouldn't risk running anything off a damaged header. There are plenty of other options of add-in pcie cards that have internal & external usb3 ports if that helps.
had this happen to an asus sabertooth. instead of trying to resolder the pin, i simply stuffed solder wire down the corresponding slot in the USB 3 plug, then melted the tip of the wire so it was just a small bulge on the plug. worked like a charm.
