Been bashing my head against this for weeks now. If anyone has any suggestions I’d be very grateful!!
I have PVE 8.3 installed on a machine with a dual port SFP+ NIC (X710-DA2). I’ve set up SR-IOV VF’s using these udev rules:
ACTION=="add", SUBSYSTEM=="net", ENV{INTERFACE}=="enp1s0f0np0", ATTR{device/sriov_numvfs}="3"
ACTION=="add", SUBSYSTEM=="net", ENV{INTERFACE}=="enp1s0f1np1", ATTR{device/sriov_numvfs}="3"
Using the PVE GUI, I’ve set up a bridge on a bond on two of the VF’s resulting in the following interfaces file:
auto lo
iface lo inet loopback
auto enp1s0f0v0
iface enp1s0f0v0 inet manual
auto enp1s0f1v0
iface enp1s0f1v0 inet manual
auto bond0
iface bond0 inet manual
bond-slaves enp1s0f0v0 enp1s0f1v0
bond-miimon 100
bond-mode active-backup
bond-primary enp1s0f0v0
auto vmbr0
iface vmbr0 inet manual
bridge-ports bond0
bridge-vlan-aware yes
bridge-vids 2-4094
bridge-stp off
bridge-fd 0
auto vmbr0.10
iface vmbr0.10 inet static
address 10.7.0.20/24
gateway 10.7.0.1
source /etc/network/interfaces.d/*
After applying the changes, the network works as expected. After a reboot, though, none of the interfaces come up:
> ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp1s0f0np0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 68:05:ca:9b:d6:84 brd ff:ff:ff:ff:ff:ff
vf 0 link/ether ba:4e:ac:fb:fe:ef brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state auto, trust off
vf 1 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state auto, trust off
vf 2 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state auto, trust off
3: enp1s0f1np1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 68:05:ca:9b:d6:85 brd ff:ff:ff:ff:ff:ff
4: eno1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 8c:16:45:92:88:9b brd ff:ff:ff:ff:ff:ff
altname enp0s31f6
5: enp1s0f0v0: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master bond0 state DOWN mode DEFAULT group default qlen 1000
6: enp1s0f1v0: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master bond0 state DOWN mode DEFAULT group default qlen 1000
7: enp1s0f0v1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 86:62:db:16:bf:ef brd ff:ff:ff:ff:ff:ff
8: enp1s0f1v1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether e6:93:a7:a5:17:b9 brd ff:ff:ff:ff:ff:ff
9: enp1s0f1v2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether de:7d:9a:5c:a5:a3 brd ff:ff:ff:ff:ff:ff
10: enp1s0f0v2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 96:cd:ab:44:2c:57 brd ff:ff:ff:ff:ff:ff
11: bond0: <NO-CARRIER,BROADCAST,MULTICAST,MASTER,UP> mtu 1500 qdisc noqueue master vmbr0 state DOWN mode DEFAULT group default qlen 1000
12: vmbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
13: vmbr0.10@vmbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000
I’m not seeing any dmesg errors or even ifupdown2 errors in the debug logs. All the commands run successfully, but the links just aren’t up. The weird thing is, if I give the bond a static IP, then it comes up just fine. Also - if I stop using SR-IOV VF’s it also works. So there’s some interaction, but I have no idea what.
