Sata and power cables swapped. Drive appears to not even spin.
I took it back to the store I bought it from, only to be shown that the drive operates normally and they can’t be sure why it’s not working for me. Not willing, not able (?) to provide me with any solution, I resolved to the internet with little to no avail yet.
I opened up a support case with WD describing all the above, and I await their input.
Anyone here that can shed some light and extinguish my frustration please?
In the current spec, pins 1 and 2 are reserved and unused, 3 is for 3.3 v. So there is no harm in taping 1 & 2 and I find it hard to work with such a thin piece of tape. Taping all three makes it more likely the tape stays on when you plug the power cord on instead of just rolling it up an uncovering pin 3.
I have been running dd if=/dev/random of=/dev/md0 for the better part of decade trying to find the pattern I know is in there somewhere. And I may need to go another decade to nail it down.
What kind of SATA connector is that on the adapter? Is it the kind where the plastic is molded around the wires or the kind that is crimped? The molded ones are pretty cheap and have been known to kill drives by shorting/burning whereas the crimped ones are higher quality.
