Bout time i built my own
Ok so i have built PCs for friends and modified mine a good bit. I have finally made enough money to build a decent PC. So i went on newegg.com and picked the parts I want, but im always looking for improvement as long as its within my price range(600). So im gonna give the specs and feel free to tell me what i should change but all i ask is you give me a reason why this is an upgrade. Thanks :D
CPU: AMD fx 6300 Vishera 3.5 Ghz 110$
GPU: MSI R9 270x 2gb gddr5 200$
Motherboard: MSI 970A-g43 am3+ 70$
Hard drive: Wd caviar blue 500gb 60$
RAM: Kingston HyperX Blu 8gb (2 x 4) 88$
PSU: EVGA 500 B 80 Plus Bronze 50$
Case: NZXT Source 210 w/ window 45$
The main thing i want to change is ram i just want a bit of a cheaper price
what are you trying to do with this? game, workstation, video rendering? and what are your expectations of performance
I plan on gaming, nothing too extreme. Also some minor video editing.
As long as you don't overclock that CPU, it'll be fine.  Motherboard is a bit on the cheap side.
Yea i made sure the motherboard had everything i needed and nothing i don't. I plan on upgrading in the future.
go for a 1TB hard drive, the price difference between 500GB and 1TB isn't that big. only like $5+
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Yea i realized that and upgraded i have my parts and i built my pc and it runs great. Thanks tho :D
