Go into File Explorer. Right click on 'Computer' and select Manage. Go to Disk Management. There you should be able to see all the partitions of your hard drive, or the lack thereof. If all that space is unallocated, you should be able to select you local disk (C) and expand the storage so it fills the rest of the disk.
