Borderlands 2 FPS issues
I have an FX8350 and a 7870 and i can play the BF3 Campaign maxed out just fine  <!--brake>  (my internet doesn't allow for Multilayer and BF3, which i got in the humblebundle, is the most intensive game i have played with my computer since it is a 2 weeks old).
in borderlands 2, which i just download from Steam a few days ago, is only getting 10-25FPS on average (sometimes above 30 but not for long). this is with the game @720p on lowest settings and PhysX set to low (i tried to turn it off but it would only go to low).  in battles is where the FPS is around 10 or less, but on the other hand i can get guns and shoot the snow and throw grenades and it not effect the FPS at all.
i am puzzled it seems to only do it with AI around. the first big boss scene with the 2 brothers, 1 in the turret cannon. frames were very bad glitching the hole time (i almost turned it off but i wanted a checkpoint).  after they died i jumped in to the gun and blasted everything i could no real affect on the FPS.
My FX8350 has none of the CPU cores getting above 20% utilization, when i make the game run on every other core to have 1 thread on 1 module i get 4 threads around 30% utilization.
MY 7870 never get above 35% utilization measured with MSI afterburner (which i downloaded it just for the cool graph it has).
i also have DDR3 8GB (4GBx2 DC) 1333MHz, 320GB 5400RPM drive (just because i am cheap and have not got an SSD yet).  do you think the Memory or the HDD could be bottle necking the whole game?
Update graphics card drivers and turn off filters
That will be your hdd i am gessing i have bodderlands 2 set to max all setings 1920x1080 PhysX low and i have it caped to 72fps in the setings useing a HD7850 + FX8320 The game likes to load off the hdd a lot and you can tell when you get a area that loads from the drive you get a little fps drop as it loads the area.
The ram makes no differnce.
It dosent use much cpu power at all.
Allso have you instaled the windows hot fixe's?
http://hotfixv4.microsoft.com/Windows%207/Windows%20Server2008%20R2%20SP1/sp2/Fix387870/7600/free/441065_intl_x64_zip.exe
http://hotfixv4.microsoft.com/Windows%207/Windows%20Server2008%20R2%20SP1/sp2/Fix391262/7600/free/441280_intl_x64_zip.exe
I suggest you apply core parking updates (I assume you are running windows 7), as they can cause cpu cores to underutalised in poorly threaded applications, which could be your issue. If not then... try beta drivers or older drivers.
http://support.microsoft.com/kb/2646060
how did you get the display at the top left?
thanks for trying to help.
the GPU drivers are only 2 weeks old and BL2 is a lot older than that
the hotfixes you guys sent it says that it "doesn't apply to my system", i tried to install it 2 weeks ago when i first built the computer ad it said that then.
i am downloading the updated PhysX drivers to see if that is it or not.
and again, this is only really happens when there are enemies around, and for some reason it doesn't even hit 30fps.
HWiNFO64+msi afterburner.
You use HWiNFO64 to add anything you like to msi afterburners on screen display.
http://event.msi.com/vga/afterburner/download.htm
http://www.majorgeeks.com/files/details/hwinfo64.html
ok i have it working a little better now, there was a setting were it was setting it to cap the FPS at 30 or something, but i set it to unlimited.  now i am getting up to ~45 with an average of 30FPS now,  also i still have a problem of it dropping down to 15 randomly when there are enemies on the map. CPU and GPU utilization are still very low.
i do not think it is the PhysX because the phase lock has a gravity field on it and pulls in a bunch of rocks and the FPS stays constant during that sequence above 25.
also, i think that the game auto selected the highest settings but kept the physx on low, but the setting the fps to unlimited has helped a little.
i have moved the PhysX to Medium with very little FPS effect and this is with the CPU running it because no Nvidia card present.
well everyone, i have it fixed.  i am getting above 60FPS now; and i feel like an idiot.
long story short, i was testing out different clock rates for the FX8350, in the ASUS suite that the mobo came with, i set the cpu to a low power mode where it get to a max of 1400MHz (default 4000).
i thought i put it back to default and i haven't messed with it for over a week now, i have been playing Borderlands 1 and Battlefield 3 with no problems (with Borderlands 1 being a 5 year old game and BF3 multi-threading very well).
using the HwiNFO software i can tell that 4 cpu cores @4GHz were being used in BL2 (average fore each core 46, 7, 41, 70, 5, 42, 10, 18).  i am sum-what surprised that the newest PhysX drivers are not threaded better for the CPU (more that 4 cores being used).
Again every one Thanks for the help
