Booting Up
I built my pc and i did a test. But once i turn on the system, it shuts off after a few seconds. I don't know what the problem is
Mobo: asus m5a97 r2.0
ram: gskill sniper series 8gb (2x4)
cpu: 8350 vishera
Video card: http://www.zotacusa.com/geforce-gt-620-synergy-1gb-zt-60502-10l.html
psu: EVGA supernova 650g
Does it POST? Does it have any BIOS beeps? Debug LEDs?
It could be any number of things.
If you dont get post or hear beep (if you got internal speaker plugged in) that sounds like ram problem. You should check that your ram configuration is right (check from the mother board manual) if it does not post after that try with single stick of ram in diffrent slots and repeat same with the other stick! Post more info if that does not work.
