Boot/USB3.0 problems
So I just finished building my rig and I'm having problems when I plug in my mouse to my USB 3.0 port. I installed all the drivers for the motherboard and the USB 3.0 connection either fails on me or becomes really flaky.  Also sometimes the boot gets stuck on the windows logo if my mouse is plugged in.  I even tried installing drivers from the disc that came with my motherboard and it still doesn't work. By the way my specs are
Asrock Extreme 4 z77 mobo
Intel core i5 3570k
8gb of g.skill ripjaws ddr3 1600MHz ram
650w psu
1tb hdd
60gb ssd
Radeon 7870 core edition
Asus disc drive
Any help would be greatly appreciated. THX
Might want to plug your mouse into a usb 2.0 port instead, more compatible
I still want to make use of my USB 3.0 ports though, still have a coupIe other peripherals
Update: just realized that when Iplugged and unplug from my ports the ports all together stop working
Might be a faulty board. I would do an RMA or call then to troubleshoot the problem
It's only happening when I use my mouse.  Not my keyboard or Xbox controller
It's only happening with my mouse
then that might be the mouses fault
I just tested it out on mylaptop and seams to work fine
Also it's not letting me shut down when the ports freeze up
(I am not responsible for any damage caused)
Is there a bios updates on your board? Did you personally install the latest drivers because sometimes MS only istalls its default driver sets. Not the ones the manufacturer of the chips recommends.
I looked up your board and it has a lot of bios updates (if I looked up the correct one). Are you running 2.00 because some of the earlier updates have usb fixes in them(which will be included in the latest bios version also. Try updating your bios to the latest version and see if that helps. If you don't know how to update your bios read carefully before attempting as a bad bios flash can ruin a board.
Go to the actual ASrock site for the downloads.
