when trying to bookmark a post (not a whole thread)
steps:
go to a post
click the dots
click the bookmark thing
steps:
go to a post
click the dots
I don´t like the “3 dots menu” either.
the dots dont bother me… but without hovering over the bookmark icon… you cant tell it was bookmarked… and you cant hover on mobile.
You are right. That is indeed a problem.
Directly under the posts there is a “bookmark” button. It seems to work on mobile too.
Then under the “bookmark” button there is a “normal” button that I can change to “tracking”, which is what I do to most threads I want to follow. I’ve never used the 3 dot thing, never knew what it did.
