Same output unfortunately:
sudo modprobe nct6775
modprobe: ERROR: could not insert 'nct6775': No such device
Brilliant - and that on a 4.18 kernel where it should be supported.
Anyway unfortunately I’ve got to go now, we’ll take a look tomorrow again what it might be.
super late here
@catsay Since @George_Keough said Mint ships that module I’ll give it a go in the meantime to see if it’s the same there. Thanks
You can just check to see if the module is included in your version with…
modinfo nct6775
That will tell you if it is installed. We are using similar kernel versions so it should be. I found a lot of people having trouble getting it working while I was attempting to get mine working. I still haven’t decided if I’m daring enough to try to write a module for my chipset.
Running that gives:
modinfo nct6775
filename: /lib/modules/4.18.0-13-generic/kernel/drivers/hwmon/nct6775.ko
license: GPL
description: Driver for NCT6775F and compatible chips
author: Guenter Roeck <[email protected]>
srcversion: 0EEC5C46521FDEA9D4D6090
depends: hwmon-vid
retpoline: Y
intree: Y
vermagic: 4.18.0-13-generic SMP mod_unload
sig_id: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
signature: 30:82:02:A5:06:09:2A:86:48:86:F7:0D:01:07:02:A0:82:02:96:30:
82:02:92:02:01:01:31:0D:30:0B:06:09:60:86:48:01:65:03:04:02:
03:30:0B:06:09:2A:86:48:86:F7:0D:01:07:01:31:82:02:6F:30:82:
02:6B:02:01:01:30:46:30:2E:31:2C:30:2A:06:03:55:04:03:0C:23:
42:75:69:6C:64:20:74:69:6D:65:20:61:75:74:6F:67:65:6E:65:72:
61:74:65:64:20:6B:65:72:6E:65:6C:20:6B:65:79:02:14:40:71:35:
68:4F:B5:09:52:A4:1C:79:66:D0:19:CB:22:FE:F8:0B:19:30:0B:06:
09:60:86:48:01:65:03:04:02:03:30:0D:06:09:2A:86:48:86:F7:0D:
01:01:01:05:00:04:82:02:00:74:BF:90:CB:C0:08:E5:6D:C0:B3:30:
36:4C:B6:2C:0C:4B:9D:A0:6B:8C:20:13:A2:FD:08:E5:8C:68:A0:B1:
23:FF:8E:5B:E2:68:2C:30:A7:5C:50:A0:85:16:AE:73:96:82:73:2F:
8F:61:F6:EC:60:C5:38:5E:A6:E8:7D:DF:97:8A:0F:B0:FA:A9:11:C5:
8C:66:6B:0F:06:6A:5F:E7:C6:2D:8A:09:A1:E7:BD:5C:B6:B2:84:FD:
2D:9E:6B:EC:54:EA:EA:B9:25:03:F7:39:47:28:62:A5:21:DD:6C:EE:
62:B7:E5:98:C4:2E:1A:3C:C3:84:B6:CA:BF:FC:5E:54:63:5A:95:2C:
BC:66:CE:E6:8A:3E:5A:D8:C4:B2:67:2A:73:9C:F9:D7:D4:B7:BD:7A:
75:94:DC:7F:A0:CD:B9:7E:51:89:06:FB:BE:71:67:DB:0B:3B:EB:65:
18:B5:B7:A5:02:96:F2:6D:19:72:94:79:73:7F:80:07:67:78:BE:1D:
78:CE:5B:66:44:E8:22:79:FC:CB:CF:C9:9B:41:E0:52:8B:F4:3D:FB:
A7:44:1C:77:95:45:FB:CD:B0:6E:B1:AE:B5:0B:BC:FE:F7:1B:75:DD:
5C:ED:F7:91:88:30:CF:A0:35:C0:AA:FC:91:81:80:23:A7:23:CE:53:
97:74:20:B1:46:75:33:DF:EF:1F:07:3E:F7:A1:39:15:53:12:FF:9F:
96:C0:BF:A7:C6:CF:7B:C6:3E:AA:6B:5B:A0:0E:4F:EC:BE:DD:53:45:
B0:A4:48:31:66:FB:FC:5B:39:32:35:F5:12:3F:21:2B:42:DE:5B:79:
48:39:DC:41:0B:B1:01:91:3D:23:FA:F1:A9:3D:0E:BB:75:CD:51:26:
B6:0B:23:EA:EF:D6:27:51:03:F0:20:B1:21:D4:8E:F7:AB:38:73:DC:
78:ED:E0:1A:06:14:B7:4A:5A:98:58:C5:67:30:9F:5D:71:C9:B1:54:
1D:2C:4F:7A:0C:F3:01:19:BB:56:A5:B1:A6:64:0E:E1:AD:CB:1B:D5:
6D:EB:30:C8:30:B6:65:D0:26:38:6F:69:3B:C9:7C:64:97:9D:DC:5A:
3A:DF:D7:67:16:98:E2:DF:47:AE:55:12:65:E7:59:6F:8C:BD:0D:41:
5B:0B:9E:EC:A5:7B:33:78:B2:03:3B:38:0F:9F:20:55:18:02:46:8A:
B8:48:EE:6D:EC:74:E7:43:82:42:FF:74:4A:FC:A3:F3:06:2F:AC:44:
C5:9F:D3:6E:47:40:CA:B9:A1:8D:3C:BA:76:D2:DC:F2:AC:BE:9A:1C:
3F:EC:4A:6C:9B:CD:6D:1B:1B:F6:F5:00:E8:F8:2B:68:8E:6E:D1:67:
5F
parm: force_id:Override the detected device ID (ushort)
parm: fan_debounce:Enable debouncing for fan RPM signal (ushort)
So I guess it is installed but modprobe cannot find it?
Sounds like that is the case, have you tried to get just the script from the new lm-sensors. You get the same unknown address that I get.
I downloaded the latest version of lm-sensors from https://github.com/lm-sensors/lm-sensors and then followed the instructions in the Makefile. So I installed whatever dependencies were not installed and ran make all
and then make install
Then I tried sudo apt-cache policy lm-sensors
and I get the same version as before ( 1:3.4.0-4). Also running sensors-detect --auto
gives the same unknown chip as before. Tried rebooting, still the same. Do you maybe have a suggestion as to how to go futher from here? I also tried doing sensors-detect --auto
in a live Mint session but it also did not recognize the chipset.
Sorry, I’ve reached the end of my knowledge on this subject. The only other thing I can suggest is that you try and run the sensors-detect from the git download folder. For example I have a folder in my home directory:
~/git/
I run any git commands from there then go into the sub folders where you downloaded, go into /lm-sensors/prog/detect/
from there run:
sudo ./sensors-detect --auto
See if that gives you a different results. I don’t think it will, but look at the first line of output to at least be certain you are not using the 2015 version.
Now this is the first line # sensors-detect revision $Revision$
Thanks a lot for your help. It definitely helped with narrowing down the issue.
That’s actually what I get with that script as well. I am hopeful you will find an answer. I am still trying to find enough information on the Super I/O chip on my motherboard to make any progress, although I’ve decided I don’t really care enough to worry about it.
If somebody is still following this, I add below the output of the installation of lm-sensors from the github page:
hunter@Hunter:~/Downloads/lm-sensors-master$ make clean
rm -f lib/*.ld lib/*.ad
rm -f lib/*.lo lib/*.ao
rm -f lib/libsensors.so.5.0.0 lib/libsensors.so.5 lib/libsensors.so lib/libsensors.a lib/conf-parse.h lib/conf-parse.c lib/conf-lex.c
rm -f lib/libsensors.so.*
rm -f prog/sensors/*.rd prog/sensors/*.ro
rm -f prog/sensors/sensors
rm -f prog/dump/*.rd prog/dump/*.ro prog/dump/isadump prog/dump/isaset
rm -f lib/test/*.rd lib/test/*.ro
rm -f lib/test/test-scanner
rm -f lm_sensors-* lex.backup
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/dump/superio.c | \
sed -e 's@^\(.*\)\.o:@prog/dump/superio.rd prog/dump/superio.ro: Makefile '`dirname prog/dump/superio.rd`/Module.mk' @' > prog/dump/superio.rd
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/dump/isaset.c | \
sed -e 's@^\(.*\)\.o:@prog/dump/isaset.rd prog/dump/isaset.ro: Makefile '`dirname prog/dump/isaset.rd`/Module.mk' @' > prog/dump/isaset.rd
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/dump/isadump.c | \
sed -e 's@^\(.*\)\.o:@prog/dump/isadump.rd prog/dump/isadump.ro: Makefile '`dirname prog/dump/isadump.rd`/Module.mk' @' > prog/dump/isadump.rd
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/dump/util.c | \
sed -e 's@^\(.*\)\.o:@prog/dump/util.rd prog/dump/util.ro: Makefile '`dirname prog/dump/util.rd`/Module.mk' @' > prog/dump/util.rd
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/sensors/chips.c | \
sed -e 's@^\(.*\)\.o:@prog/sensors/chips.rd prog/sensors/chips.ro: Makefile '`dirname prog/sensors/chips.rd`/Module.mk' @' > prog/sensors/chips.rd
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef prog/sensors/main.c | \
sed -e 's@^\(.*\)\.o:@prog/sensors/main.rd prog/sensors/main.ro: Makefile '`dirname prog/sensors/main.rd`/Module.mk' @' > prog/sensors/main.rd
/usr/bin/bison
bison -p sensors_yy -d lib/conf-parse.y -o lib/conf-parse.c
/usr/bin/flex
flex -Psensors_yy -t -Cfe -8 lib/conf-lex.l > lib/conf-lex.c
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/conf-lex.c | \
sed -e 's@^\(.*\)\.o:@lib/conf-lex.ad lib/conf-lex.ao: Makefile '`dirname lib/conf-lex.ad`/Module.mk' @' > lib/conf-lex.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/conf-parse.c | \
sed -e 's@^\(.*\)\.o:@lib/conf-parse.ad lib/conf-parse.ao: Makefile '`dirname lib/conf-parse.ad`/Module.mk' @' > lib/conf-parse.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/sysfs.c | \
sed -e 's@^\(.*\)\.o:@lib/sysfs.ad lib/sysfs.ao: Makefile '`dirname lib/sysfs.ad`/Module.mk' @' > lib/sysfs.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/init.c | \
sed -e 's@^\(.*\)\.o:@lib/init.ad lib/init.ao: Makefile '`dirname lib/init.ad`/Module.mk' @' > lib/init.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/access.c | \
sed -e 's@^\(.*\)\.o:@lib/access.ad lib/access.ao: Makefile '`dirname lib/access.ad`/Module.mk' @' > lib/access.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/error.c | \
sed -e 's@^\(.*\)\.o:@lib/error.ad lib/error.ao: Makefile '`dirname lib/error.ad`/Module.mk' @' > lib/error.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/general.c | \
sed -e 's@^\(.*\)\.o:@lib/general.ad lib/general.ao: Makefile '`dirname lib/general.ad`/Module.mk' @' > lib/general.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/data.c | \
sed -e 's@^\(.*\)\.o:@lib/data.ad lib/data.ao: Makefile '`dirname lib/data.ad`/Module.mk' @' > lib/data.ad
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/conf-lex.c | \
sed -e 's@^\(.*\)\.o:@lib/conf-lex.ld lib/conf-lex.lo: Makefile '`dirname lib/conf-lex.ld`/Module.mk' @' > lib/conf-lex.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/conf-parse.c | \
sed -e 's@^\(.*\)\.o:@lib/conf-parse.ld lib/conf-parse.lo: Makefile '`dirname lib/conf-parse.ld`/Module.mk' @' > lib/conf-parse.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/sysfs.c | \
sed -e 's@^\(.*\)\.o:@lib/sysfs.ld lib/sysfs.lo: Makefile '`dirname lib/sysfs.ld`/Module.mk' @' > lib/sysfs.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/init.c | \
sed -e 's@^\(.*\)\.o:@lib/init.ld lib/init.lo: Makefile '`dirname lib/init.ld`/Module.mk' @' > lib/init.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/access.c | \
sed -e 's@^\(.*\)\.o:@lib/access.ld lib/access.lo: Makefile '`dirname lib/access.ld`/Module.mk' @' > lib/access.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/error.c | \
sed -e 's@^\(.*\)\.o:@lib/error.ld lib/error.lo: Makefile '`dirname lib/error.ld`/Module.mk' @' > lib/error.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/general.c | \
sed -e 's@^\(.*\)\.o:@lib/general.ld lib/general.lo: Makefile '`dirname lib/general.ld`/Module.mk' @' > lib/general.ld
gcc -M -MG -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef lib/data.c | \
sed -e 's@^\(.*\)\.o:@lib/data.ld lib/data.lo: Makefile '`dirname lib/data.ld`/Module.mk' @' > lib/data.ld
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/data.c -o lib/data.lo
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/general.c -o lib/general.lo
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/error.c -o lib/error.lo
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/access.c -o lib/access.lo
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/init.c -o lib/init.lo
In file included from /usr/include/x86_64-linux-gnu/sys/types.h:25,
from lib/init.c:25:
/usr/include/features.h:184:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
# warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/sysfs.c -o lib/sysfs.lo
lib/sysfs.c: In function ‘find_bus_type’:
lib/sysfs.c:637:8: warning: ‘/class/i2c-adapter/i2c-’ directive output may be truncated writing 23 bytes into a region of size between 1 and 255 [-Wformat-truncation=]
"%s/class/i2c-adapter/i2c-%d/device",
lib/sysfs.c:637:5: note: directive argument in the range [-32768, 32767]
In file included from /usr/include/stdio.h:873,
from lib/sensors.h:25,
from lib/data.h:25,
from lib/sysfs.c:34:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:67:10: note: ‘__builtin___snprintf_chk’ output between 32 and 291 bytes into a destination of size 255
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
lib/sysfs.c: In function ‘sensors_read_dynamic_chip’:
lib/sysfs.c:408:31: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 254 [-Wformat-truncation=]
snprintf(path, NAME_MAX, "%s/%s", device, attr);
from lib/data.h:25,
/usr/include/x86_64-linux-gnu/bits/stdio2.h:67:10: note: ‘__builtin___snprintf_chk’ output 2 or more bytes (assuming 257) into a destination of size 255
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -Wno-undef -c lib/conf-parse.c -o lib/conf-parse.lo
gcc -DETCDIR="\"/etc\"" -I. -fpic -D_REENTRANT -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -Wno-shadow -Wno-undef -Wno-unused -Wno-missing-prototypes -Wno-sign-compare -c lib/conf-lex.c -o lib/conf-lex.lo
gcc -shared -Wl,--version-script=lib/libsensors.map -Wl,-soname,libsensors.so.5 -o lib/libsensors.so.5.0.0 lib/data.lo lib/general.lo lib/error.lo lib/access.lo lib/init.lo lib/sysfs.lo lib/conf-parse.lo lib/conf-lex.lo -lc -lm
ln -sf libsensors.so.5.0.0 lib/libsensors.so.5
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/data.c -o lib/data.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/general.c -o lib/general.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/error.c -o lib/error.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/access.c -o lib/access.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/init.c -o lib/init.ao
from lib/init.c:25:
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/sysfs.c -o lib/sysfs.ao
from lib/data.h:25,
from lib/data.h:25,
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -Wno-undef -c lib/conf-parse.c -o lib/conf-parse.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -Wno-shadow -Wno-undef -Wno-unused -Wno-missing-prototypes -Wno-sign-compare -c lib/conf-lex.c -o lib/conf-lex.ao
rm -f lib/libsensors.a
ar rcvs lib/libsensors.a lib/data.ao lib/general.ao lib/error.ao lib/access.ao lib/init.ao lib/sysfs.ao lib/conf-parse.ao lib/conf-lex.ao
a - lib/data.ao
a - lib/general.ao
a - lib/error.ao
a - lib/access.ao
a - lib/init.ao
a - lib/sysfs.ao
a - lib/conf-parse.ao
a - lib/conf-lex.ao
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/sensors/main.c -o prog/sensors/main.ro
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/sensors/chips.c -o prog/sensors/chips.ro
gcc -Wl,-rpath,/usr/local/lib -o prog/sensors/sensors prog/sensors/main.ro prog/sensors/chips.ro -Llib -lsensors
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/dump/isadump.c -o prog/dump/isadump.ro
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/dump/superio.c -o prog/dump/superio.ro
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/dump/util.c -o prog/dump/util.ro
gcc -Wl,-rpath,/usr/local/lib -o prog/dump/isadump prog/dump/isadump.ro prog/dump/superio.ro prog/dump/util.ro
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c prog/dump/isaset.c -o prog/dump/isaset.ro
gcc -Wl,-rpath,/usr/local/lib -o prog/dump/isaset prog/dump/isaset.ro prog/dump/util.ro
gcc -DETCDIR="\"/etc\"" -I. -Wall -O2 -Wstrict-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wnested-externs -Winline -W -Wmissing-prototypes -Wundef -c lib/test/test-scanner.c -o lib/test/test-scanner.ro
gcc -Wl,-rpath,/usr/local/lib -o lib/test/test-scanner lib/test/test-scanner.ro lib/conf-lex.ao lib/error.ao lib/general.ao -Llib
hunter@Hunter:~/Downloads/lm-sensors-master$ sudo make install
mkdir -p /usr/local/lib /usr/local/include/sensors /usr/local/man/man3 /usr/local/man/man5
Warning: This is the first installation of the libsensors.so.5*
library files in /usr/local/lib!
You must update the library cache or the userspace tools may fail
or have unpredictable results!
Run the following command: /sbin/ldconfig
install -m 644 lib/libsensors.a /usr/local/lib
install -m 755 lib/libsensors.so.5.0.0 /usr/local/lib
ln -sf libsensors.so.5.0.0 /usr/local/lib/libsensors.so.5
ln -sf libsensors.so.5 /usr/local/lib/libsensors.so
install -m 644 lib/error.h lib/sensors.h /usr/local/include/sensors
install -m 644 lib/libsensors.3 /usr/local/man/man3
install -m 644 lib/sensors.conf.5 /usr/local/man/man5
ln -sf sensors.conf.5 /usr/local/man/man5/sensors3.conf.5
mkdir -p /usr/local/sbin /usr/local/man/man8
install -m 755 prog/detect/sensors-detect /usr/local/sbin
install -m 644 prog/detect/sensors-detect.8 /usr/local/man/man8
install -m 755 prog/pwm/fancontrol prog/pwm/pwmconfig /usr/local/sbin
install -m 644 prog/pwm/fancontrol.8 prog/pwm/pwmconfig.8 /usr/local/man/man8
mkdir -p /usr/local/bin /usr/local/man/man1
install -m 755 prog/sensors/sensors /usr/local/bin
install -m 644 prog/sensors/sensors.1 /usr/local/man/man1
mkdir -p /etc /etc/sensors.d
if [ ! -e /etc/sensors3.conf ] ; then \
install -m 644 etc/sensors.conf.default /etc/sensors3.conf ; \
fi
install -m 755 etc/sensors-conf-convert /usr/local/bin
if [ -e /etc/modprobe.d/lm_sensors \
-a ! -e /etc/modprobe.d/lm_sensors.conf ] ; then \
mv -f /etc/modprobe.d/lm_sensors /etc/modprobe.d/lm_sensors.conf ; \
fi
mkdir -p /usr/local/man/man8
install -m 644 etc/sensors-conf-convert.8 /usr/local/man/man8
install -m 755 prog/dump/isadump prog/dump/isaset /usr/local/sbin
install -m 644 prog/dump/isadump.8 prog/dump/isaset.8 /usr/local/man/man8
*** Important notes:
*** * The libsensors configuration file (/etc/sensors3.conf) is never
*** overwritten by our installation process, so that you won't lose
*** your personal settings in that file. You still can get our latest
*** default config file in etc/sensors.conf.default and manually copy
*** it to /etc/sensors3.conf if you want. You will then want to
*** edit it to fit your needs again.
*** * The format of /etc/sensors3.conf changed with lm-sensors 3.0.0.
*** If you have a custom configuration file using the old format, you
*** can convert it using the sensors-conf-convert script. Otherwise just
*** overwrite your old configuration file with the new default one.
*** * As of lm-sensors 3.1.0, the default configuration file only
*** contains statements which do not depend on how chips are wired.
*** If you miss parts of the bigger configuration file that used to be
*** the default, copy the relevant parts from etc/sensors.conf.eg to
*** /etc/sensors3.conf.
Hopefully somebody will be able to make sense out of that
Did you enable acpi_enforce_resources=lax for GRUB_CMDLINE_LINUX_DEFAULT in the grub config?
At least with the MSI boards they are using Nuvoton Super I/O chips that are somewhat supported. Most of the X370, B350, X470 and B450 boards from GigaByte use ITE Super i/o chips that required an experimental module that the developer pulled from GitHub last summer because he was tired of not getting any support to have it mainlined.
I’ve had to use a similar process on my GigaByte Boards to get lm-sensors working.
