I hope someone here may be able to help me out.
I am running a ASRock X399 Fatal1ty motherboard with a Threadripper 2950x.
I am not really sure where the problem is, but it started yesterday. The only packages I updated in relation to bluetooth were bluez-qt ( 5.54.0-1 -> 5.55.0-1 ), modemmanager-qt (5.54.0-1 -> 5.55.0-1), networkmanager-qt (5.54.0-1 -> 5.55.0-1).
I rolled them back, but no change.
Whenever I go to connect a bluetooth device, it will connect for a moment, then immediately disconnect. But the bluetooth adapter still thinks the device is connected.
Everything was working great on the 10th, I played Rocket League for a couple hours and had 0 issues with my bluetooth controller.
Now I can’t even get a bluetooth headset to pair.
I am starting to think there may be a hardware issue here, but then again, my WiFi is working perfectly, and they are on the same card. The adapter is a Intel Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10).
Here is my dmesg, journalctl, and systemctl output.
dmesg |grep -i bluetooth
[ 15.937915] Bluetooth: Core ver 2.22
[ 15.937942] Bluetooth: HCI device and connection manager initialized
[ 15.937947] Bluetooth: HCI socket layer initialized
[ 15.937950] Bluetooth: L2CAP socket layer initialized
[ 15.937955] Bluetooth: SCO socket layer initialized
[ 16.167433] Bluetooth: hci0: read Intel version: 370810225019140f34
[ 16.167437] Bluetooth: hci0: Intel device is already patched. patch num: 34
[ 18.929264] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.929266] Bluetooth: BNEP filters: protocol multicast
[ 18.929270] Bluetooth: BNEP socket layer initialized
[ 29.020464] Bluetooth: RFCOMM TTY layer initialized
[ 29.020469] Bluetooth: RFCOMM socket layer initialized
[ 29.020475] Bluetooth: RFCOMM ver 1.11
[ 227.555393] Bluetooth: hci0: failed to disable LE scan: status 0x0c
[ 3025.087064] audit: type=1131 audit(1549982690.820:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 3025.489338] audit: type=1130 audit(1549982691.223:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 3170.468539] Bluetooth: hci0: failed to disable LE scan: status 0x0c
[ 4415.987646] audit: type=1131 audit(1549984081.728:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 4416.384426] audit: type=1130 audit(1549984082.124:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 4530.500304] audit: type=1131 audit(1549984196.242:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 4530.893556] audit: type=1130 audit(1549984196.635:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 4589.552851] Bluetooth: hci0: failed to disable LE scan: status 0x0c
journalctl -b -g bluetooth
– Logs begin at Tue 2018-12-25 01:33:43 EST, end at Tue 2019-02-12 10:33:34 EST. –
Feb 12 08:54:41 kernel: Bluetooth: Core ver 2.22
Feb 12 08:54:41 kernel: Bluetooth: HCI device and connection manager initialized
Feb 12 08:54:41 kernel: Bluetooth: HCI socket layer initialized
Feb 12 08:54:41 kernel: Bluetooth: L2CAP socket layer initialized
Feb 12 08:54:41 kernel: Bluetooth: SCO socket layer initialized
Feb 12 08:54:41 kernel: Bluetooth: hci0: read Intel version: 370810225019140f34
Feb 12 08:54:41 kernel: Bluetooth: hci0: Intel device is already patched. patch num: 34
Feb 12 08:54:44 systemd[1]: Starting Bluetooth service…
Feb 12 08:54:44 bluetoothd[1197]: Bluetooth daemon 5.50
Feb 12 08:54:44 systemd[1]: Started Bluetooth service.
Feb 12 08:54:44 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 08:54:44 systemd[1]: Reached target Bluetooth.
Feb 12 08:54:44 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 12 08:54:44 kernel: Bluetooth: BNEP filters: protocol multicast
Feb 12 08:54:44 kernel: Bluetooth: BNEP socket layer initialized
Feb 12 08:54:44 bluetoothd[1197]: Bluetooth management interface 1.14 initialized
Feb 12 08:54:44 NetworkManager[1196]: [1549979684.9017] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-bluetooth.so)
Feb 12 08:54:54 kernel: Bluetooth: RFCOMM TTY layer initialized
Feb 12 08:54:54 kernel: Bluetooth: RFCOMM socket layer initialized
Feb 12 08:54:54 kernel: Bluetooth: RFCOMM ver 1.11
Feb 12 08:54:55 systemd[1395]: Starting Bluetooth OBEX service…
Feb 12 08:54:55 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 08:54:55 systemd[1395]: Started Bluetooth OBEX service.
Feb 12 08:54:59 plasmashell[1509]: org.kde.plasmaquick: New Applet “Bluetooth” with a weight of 54
Feb 12 08:55:01 plasmashell[1509]: org.kde.plasmaquick: Delayed preload of “Bluetooth” after 1.899 seconds
Feb 12 08:55:01 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 41 msec
Feb 12 08:57:58 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 08:57:58 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 59
Feb 12 08:58:00 kcmshell5[6246]: kf5.kconfigwidgets: A widget named ’ “kcfg_enableGlobalBluetooth” ’ was found but there is no setting named ’ “enableGlobalBluetooth” ’
Feb 12 08:58:13 kernel: Bluetooth: hci0: failed to disable LE scan: status 0x0c
Feb 12 09:44:48 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to stop ‘bluetooth.service’.”
Feb 12 09:44:50 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.814 [systemctl stop bluetooth] (owned by unix-user: stry)
Feb 12 09:44:50 systemd[1]: Stopping Bluetooth service…
Feb 12 09:44:50 dbus-daemon[1193]: [system] Rejected send message, 1 matched rules; type=“error”, sender=":1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.6" (uid=0 pid=1197 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 09:44:50 dbus-daemon[1193]: [system] Rejected send message, 1 matched rules; type=“error”, sender=”:1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.6" (uid=0 pid=1197 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 09:44:50 systemd[1]: bluetooth.service: Succeeded.
Feb 12 09:44:50 systemd[1]: Stopped Bluetooth service.
Feb 12 09:44:50 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm=“systemd” exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 09:44:50 kernel: audit: type=1131 audit(1549982690.820:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 09:44:50 kdeinit5[1468]: bluedevil: Bluetooth operational changed false
Feb 12 09:44:50 systemd[1]: Starting Bluetooth service…
Feb 12 09:44:51 bluetoothd[8853]: Bluetooth daemon 5.50
Feb 12 09:44:51 systemd[1]: Started Bluetooth service.
Feb 12 09:44:51 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 09:44:51 kernel: audit: type=1130 audit(1549982691.223:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 09:44:51 dbus-daemon[1193]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.825’ (uid=0 pid=8853 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 09:44:51 bluetoothd[8853]: Bluetooth management interface 1.14 initialized
Feb 12 09:44:51 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 09:44:51 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:44:52 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:44:57 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.830 [systemctl disable bluetooth] (owned by unix-user: stry)
Feb 12 09:45:06 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.849 [systemctl enable bluetooth] (owned by unix-user: stry)
Feb 12 09:45:10 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to start ‘bluetooth.service’.”
Feb 12 09:45:13 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.864 [systemctl start bluetooth] (owned by unix-user: stry)
Feb 12 09:46:40 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:46:48 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 42 msec
Feb 12 09:46:48 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 56
Feb 12 09:46:54 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:46:54 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 61
Feb 12 09:46:57 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:47:16 kernel: Bluetooth: hci0: failed to disable LE scan: status 0x0c
Feb 12 09:47:45 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:47:45 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 66
Feb 12 09:47:52 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:50:59 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:50:59 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 71
Feb 12 09:51:04 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 09:51:07 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:51:07 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 76
Feb 12 09:55:17 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:55:17 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 81
Feb 12 09:55:27 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:55:27 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 86
Feb 12 09:57:11 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 1 msec
Feb 12 09:57:11 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 91
Feb 12 09:57:17 kcmshell5[9240]: kf5.kconfigwidgets: A widget named ’ “kcfg_enableGlobalBluetooth” ’ was found but there is no setting named ’ “enableGlobalBluetooth” ’
Feb 12 09:57:21 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 09:57:21 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 96
Feb 12 10:07:36 sudo[10070]: stry : TTY=pts/10 ; PWD=/var/cache/pacman/pkg ; USER=root ; COMMAND=/usr/bin/cp /etc/dbus-1/bluetooth.conf /etc/dbus-1/system.d/
Feb 12 10:07:49 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to restart ‘bluetooth.service’.”
Feb 12 10:07:51 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1002 [systemctl restart bluetooth] (owned by unix-user: stry)
Feb 12 10:07:51 systemd[1]: Stopping Bluetooth service…
Feb 12 10:08:01 dbus-daemon[1193]: [system] Rejected send message, 2 matched rules; type=“error”, sender=”:1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.825" (uid=0 pid=8853 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:08:01 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:08:01 systemd[1]: bluetooth.service: Succeeded.
Feb 12 10:08:01 kdeinit5[1468]: bluedevil: Bluetooth operational changed false
Feb 12 10:08:01 systemd[1]: Stopped Bluetooth service.
Feb 12 10:08:01 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm=“systemd” exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:08:01 systemd[1]: Starting Bluetooth service…
Feb 12 10:08:01 kernel: audit: type=1131 audit(1549984081.728:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:08:02 bluetoothd[10089]: Bluetooth daemon 5.50
Feb 12 10:08:02 systemd[1]: Started Bluetooth service.
Feb 12 10:08:02 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:08:02 kernel: audit: type=1130 audit(1549984082.124:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:08:02 dbus-daemon[1193]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.1011’ (uid=0 pid=10089 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:08:02 bluetoothd[10089]: Bluetooth management interface 1.14 initialized
Feb 12 10:08:02 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 10:08:02 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:08:04 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 54 msec
Feb 12 10:08:04 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 93
Feb 12 10:08:06 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:08:06 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 98
Feb 12 10:09:48 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to stop ‘bluetooth.service’.”
Feb 12 10:09:50 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1025 [systemctl stop bluetooth] (owned by unix-user: stry)
Feb 12 10:09:50 systemd[1]: Stopping Bluetooth service…
Feb 12 10:09:56 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:09:56 dbus-daemon[1193]: [system] Rejected send message, 2 matched rules; type=“error”, sender=”:1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.1011" (uid=0 pid=10089 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:09:56 systemd[1]: bluetooth.service: Succeeded.
Feb 12 10:09:56 kdeinit5[1468]: bluedevil: Bluetooth operational changed false
Feb 12 10:09:56 systemd[1]: Stopped Bluetooth service.
Feb 12 10:09:56 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm=“systemd” exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:09:56 systemd[1]: Starting Bluetooth service…
Feb 12 10:09:56 kernel: audit: type=1131 audit(1549984196.242:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:09:56 bluetoothd[10187]: Bluetooth daemon 5.50
Feb 12 10:09:56 systemd[1]: Started Bluetooth service.
Feb 12 10:09:56 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:09:56 kernel: audit: type=1130 audit(1549984196.635:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:09:56 dbus-daemon[1193]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.1036’ (uid=0 pid=10187 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:09:56 bluetoothd[10187]: Bluetooth management interface 1.14 initialized
Feb 12 10:09:56 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 10:09:57 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:10:04 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.1042 [systemctl disable bluetooth] (owned by unix-user: stry)
Feb 12 10:10:13 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.1058 [systemctl enable bluetooth] (owned by unix-user: stry)
Feb 12 10:10:19 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to start ‘bluetooth.service’.”
Feb 12 10:10:21 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1073 [systemctl start bluetooth] (owned by unix-user: stry)
Feb 12 10:10:24 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 41 msec
Feb 12 10:10:24 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 95
Feb 12 10:10:54 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:10:54 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 100
Feb 12 10:10:55 kernel: Bluetooth: hci0: failed to disable LE scan: status 0x0c
Feb 12 10:12:32 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:16:31 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to restart ‘bluetooth.service’.”
Feb 12 10:16:33 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1137 [systemctl restart bluetooth] (owned by unix-user: stry)
Feb 12 10:16:33 systemd[1]: Stopping Bluetooth service…
Feb 12 10:16:33 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:16:33 dbus-daemon[1193]: [system] Rejected send message, 2 matched rules; type=“error”, sender=”:1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.1036" (uid=0 pid=10187 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:16:33 systemd[1]: bluetooth.service: Succeeded.
Feb 12 10:16:33 kdeinit5[1468]: bluedevil: Bluetooth operational changed false
Feb 12 10:16:33 systemd[1]: Stopped Bluetooth service.
Feb 12 10:16:33 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm=“systemd” exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:16:33 systemd[1]: Starting Bluetooth service…
Feb 12 10:16:33 kernel: audit: type=1131 audit(1549984593.937:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:16:34 bluetoothd[10847]: Bluetooth daemon 5.50
Feb 12 10:16:34 systemd[1]: Started Bluetooth service.
Feb 12 10:16:34 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:16:34 kernel: audit: type=1130 audit(1549984594.350:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:16:34 dbus-daemon[1193]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.1146’ (uid=0 pid=10847 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:16:34 bluetoothd[10847]: Bluetooth management interface 1.14 initialized
Feb 12 10:16:34 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 10:16:34 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:16:35 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:16:42 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 42 msec
Feb 12 10:16:42 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 97
Feb 12 10:17:03 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:17:08 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:17:08 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 100
Feb 12 10:17:23 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:17:23 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 100
Feb 12 10:17:26 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:17:27 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:17:27 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 100
Feb 12 10:17:56 kernel: Bluetooth: hci0: failed to disable LE scan: status 0x0c
Feb 12 10:18:06 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:27:59 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to stop ‘bluetooth.service’.”
Feb 12 10:28:01 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1237 [systemctl stop bluetooth] (owned by unix-user: stry)
Feb 12 10:28:01 systemd[1]: Stopping Bluetooth service…
Feb 12 10:28:01 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:28:01 dbus-daemon[1193]: [system] Rejected send message, 2 matched rules; type=“error”, sender=”:1.101" (uid=1000 pid=1534 comm="/usr/bin/pulseaudio --daemonize=no “) interface=”(unset)" member="(unset)" error name=“org.freedesktop.DBus.Error.UnknownMethod” requested_reply=“0” destination=":1.1146" (uid=0 pid=10847 comm="/usr/lib/bluetooth/bluetoothd “)
Feb 12 10:28:01 systemd[1]: bluetooth.service: Succeeded.
Feb 12 10:28:01 kdeinit5[1468]: bluedevil: Bluetooth operational changed false
Feb 12 10:28:01 systemd[1]: Stopped Bluetooth service.
Feb 12 10:28:01 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm=“systemd” exe=”/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:28:01 systemd[1]: Starting Bluetooth service…
Feb 12 10:28:01 kernel: audit: type=1131 audit(1549985281.794:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:28:02 bluetoothd[11431]: Bluetooth daemon 5.50
Feb 12 10:28:02 systemd[1]: Started Bluetooth service.
Feb 12 10:28:02 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:28:02 kernel: audit: type=1130 audit(1549985282.151:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Feb 12 10:28:02 dbus-daemon[1193]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’ requested by ‘:1.1250’ (uid=0 pid=11431 comm="/usr/lib/bluetooth/bluetoothd ")
Feb 12 10:28:02 bluetoothd[11431]: Bluetooth management interface 1.14 initialized
Feb 12 10:28:02 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:28:02 kdeinit5[1468]: bluedevil: Bluetooth operational changed true
Feb 12 10:28:03 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:28:08 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.1256 [systemctl disable bluetooth] (owned by unix-user: stry)
Feb 12 10:28:14 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-unit-files for system-bus-name::1.1271 [systemctl enable bluetooth] (owned by unix-user: stry)
Feb 12 10:28:19 polkit-kde-authentication-agent-1[1513]: Message of action: “Authentication is required to start ‘bluetooth.service’.”
Feb 12 10:28:21 polkitd[1215]: Operator of unix-session:2 successfully authenticated as unix-user: stry to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.1286 [systemctl start bluetooth] (owned by unix-user: stry)
Feb 12 10:28:23 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 39 msec
Feb 12 10:28:23 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 97
Feb 12 10:28:29 plasmashell[1509]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: ReferenceError: btManager is not defined
Feb 12 10:28:34 plasmashell[1509]: org.kde.plasmaquick: Applet “Bluetooth” loaded after 0 msec
Feb 12 10:28:34 plasmashell[1509]: org.kde.plasmaquick: Increasing score for “Bluetooth” to 100
systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2019-02-12 10:28:02 EST; 8min ago
Docs: man:bluetoothd(8)
Main PID: 11431 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 19660)
Memory: 1.6M
CGroup: /system.slice/bluetooth.service
└─11431 /usr/lib/bluetooth/bluetoothd
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: audio-avrcp-target: Protocol not supported (93)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: Endpoint registered: sender=:1.101 path=/MediaEndpoint/A2DPSource
Feb 12 10:28:02 Dyy1-PC bluetoothd[11431]: Endpoint registered: sender=:1.101 path=/MediaEndpoint/A2DPSink
Feb 12 10:28:29 Dyy1-PC bluetoothd[11431]: Refusing input device connect: No such file or directory (2)
Update:
I no longer believe it is a hardware issue.
I tried a completely different bluetooth adapter ( USB not PCI-e ) and it does the exact same thing ( well, actually I can’t even get anything to begin to connect with it, but it is seen by the system and bluetoothctl. )
What’s even weirder is that the PCI-e bluetooth adapter can see the USB one when they are both on. But nothing will connect to either adapter. I am going to start looking at my DE’s Bluetooth stuff and see if the issue lies there.
Not quite sure where to look, but I will dig around.
Update:
I got it working, and I figured out what the issue was.
Somehow the radio was stuck in a Bluetooth LE scan mode, even after rebooting / reinstalling all bluez stuff / disable/enable services, etc.
The way I got it to work was by turning the bluetooth radio off in the UEFI and then booting into my OS, shutting down, and enabling the radio again in the UEFI. After I did that it is now working fine just like it was before.
I have no idea how it got into that mode, or what caused it. But I am glad I got it resolved.
