Bluetooth Module Passthrough
I have succesfully done passthrough for VGA and wifi
i am using Broadcom BCM943602CS module for wifi and bluetooth plugged in to pcie x1 and is compatible with mac os.
I have successfully passed through the wifi but i dont know how to pass through the bluetooth as it is an hci device and only shows when i use the
lsusb
any help will be appreciated.
Since you’re doing a macOS VM, you need a uPD720202 USB 3.0 controller flashed to a Sonnet firmware, then plug the USB header from the WiFi card into a USB port on that controller. Passing through using the QEMU USB passthrough can be unpredictable. If the VM can directly see a controller and use USB directly, it’s better that way.
https://www.tonymacx86.com/threads/making-nec-usb-3-0-card-fully-comportable-with-original-mac-drivers-caldigit-lacie-oyen.77864/
x2 on the above… I had to pass through the entire USB controller to get my m.2 based Intel Bluetooth module working on a VM. The WiFi part of the module was PCI based, but the BT was on USB and passin just the usb device did not work.
