Bluetooth Dongle/Adapter
So I am in the market for a bluetooth adapter/dongle. Primary use for a PS3 controller, secondary use for phone file transfer (can use wifi too, whatever). Can anyone recommend or vouch for one under $10 (available on amazon) that last longer than 1 month? Last one I had was a Rocketfish, just stopped working after 1 month and never got another since (2008).
I see those on amazon under $3, too good to be true... you get what you pay for...
Advice?
If you are using it primarily for a DS3, then I would check the Motioninjoy wiki for a list of compatible dongles. (I picked up the one that Logan used in his Wiiplacement video, and it doesn't work even the slightest bit with Motioninjoy).
So my advice is go to the wiki, find a brand and/or price that suits you, and go from there.
Didn't know there was compatibility issues, thanks.
I actually got this SMK Link bluetooth for the hell of it for $20 at Fry's Electronics. Literally plug it in, paired PS3 controller, done. Now I wonder how/if it works for wiiplacement lol.
