Blue screen issue
Ok so everyday I get about 2 to 3 blue screens and I don't know what's wrong. I have updated my graphics drivers and removed and re-installed them. It says physical memory dump if that matter's. I have Windows 7 Home Premium 64-Bit. (I don't know what topic to put this under so move it if you have too)
Take a pic of the bluescreen so we can examine the codes. What are you typically doing when it happens?
skip the photo, upload the files from c:/windows/minidump
use dropbox or something...
after that, run cmd as admin, and use the command sfc /scannow
that will check the integrity of your windows files.
