HEADPHONES WEIGHT: 466 g DIMENSIONS CLOSED: 21cm x14cm x12cm DIMENSIONS OPEN: 18cm x 29cm x 12cm
INCLUDED ACCESSORIES Soft case with cable storage pocket 1.2-meter audio cable with Apple iPhone/iPad controls and microphone 3 meter audio cable 1 meter USB charging cable 3.5mm to 1/4" adapter
Check prices on Amazon:
Specs:
DRIVERS
TYPE AND SIZE: 50mm, fiber-reinforced dynamic driver IMPEDANCE: 42 ohms FREQUENCY RESPONSE: 15Hz-20kHz ENCLOSURE DETAILS: Sealed enclosure with tuned damping materials
lol, it looks like Logan set the comments to be sorted by date (newest-oldest) rather than popularity so that the comments liked by the community that usually accumulate at the top just get buried.
Jesus Logan, you need more than a post talking about how you want a fresh start. Everything is a mess right now and you need to put something together to formally address the problems that the company is having.
@ 1:44, My ZMF Omni headphones make the Blue-Mo Fi look like a feather weight. I recommend the Blue Lola instead if you don't want all that weight of the Mo-Fi because of all the internal components inside, and its a cheaper.
NP, but honestly his reviews can go over my head because it's so technical, especially when he's explaining the frequency measurements, so I just watch his Youtube channel instead for the laymen terms, and he does try his best to explain it for the average joe.
For those looking for an ampless version of the Mo-Fi Blue has a version of this headphone called the Lola that is much lighter and comes in much more appealing colors and can be had for less (no amp of course)
I enjoyed the video by @Logan. I do wish it was under a different name though as Tek Syndicate is dead. I also hope everything gets worked out in regards to financials so that everyone is somewhat happy or whatever.
