I have an virtual machine that I want to use a dedicated Ethernet connection separate from the one my Host uses. So I got an USB Ethernet card and plugged it in an assigned it to my VM with a static IP. So far so good.
The Problem is, when the VM is not turned on the USB Etherned card gets automatically used by my Host which is something I do not want.
Is there some thing like a blacklist on the Host or some kind of stub driver like for PCI devices that can be used so I can assign the USB network card to the VM and only to the VM and it is going to be ignored by the Host?
I never knew what udev rules were, I just heard the name a few times. This was actually the solution. I followed a guide to deauthenticate the network card and I can still pass it through.
Unfortunately it was not as easy. When I make a udev rule to deactivate the network card, I can still pass it through … I tested that yesterday. But now I realized that I can not use the card in the VM. In Ubuntu for example it is shown as a network interface but I can’t get an IP because it is doing nothing.
