I'm looking for a Bleeding Edge OS to use on both my Desktop and my Laptop. I did try to get Sabayon to install, but however I kept getting an unknown error which I clearly don't understand why. Had the same error with a Virtual Machine, both of my desktops and my laptop. So Sabayon is out of a question.
I need do need to make sure I can get quick access to my server when needed so I can get my files. I will do research on getting OpenVPN working. I do plan on trying to make it my primary OS for multiple uses. Any help will be greatful! Trying to slowly move away from Windows
I like Arch. But I tend to go for Manjaro just because it's preloaded with the stuff most people will use. I don't have time to trouble shoot Arch when something has a missing dependency or something like that.
I never heard if a distro called failed before. Sabayon is out because I keep getting an error during installation. I do have Fedora running on my desktop right now.
Just installed Manjaro and learning the ropes. Gotta say,i'm loving it. I only have one annoying quirk with it but i think that's because i screwed up the installation somehow.
You clearly are more experienced,so you shouldn't have any issues with it.
I switched over from Ubuntu after having used Ubuntu for a grand total of 2 days. Couldn't stand it. Manjaro gives me the option to learn more(correct me if i'm wrong). Messing around with the innards is how i learn. So Arch is where i want to end up but taking it at my own pace now.
well that sucks man, sabayon is pretty cool. i like how everything is compiled on the fly so practically everything you install is optimized for your system.
i bet it has something to do with UEFI, that shit confuses me.
