Blade server motherboards
Howdy people,
I got my hands on a blade server board for funzies – It’s an Asus X99-h/IPMI.
I’d like to ask: does anyone have any experience with this board and knows how to power on a blade server motherboard like this one for quick testing and validation?
Many thanks,
Y
I should clarify: I did connect all the power connectors to the board, but it doesn’t power on when I press the panel power button. I’m wondering if I’m missing something here (e.g., the backplane pins need to be shorted or something).
Looks a bit like a melon, IMO. Here’s something I found, it appears you’re not the only one:
Having said that, it seems it has 2 EATX power sockets (20 pin each) so find a PSU for that and you should at least get it powered up w/o a CPU/RAM via the IPMI port. That allows you to investigate the hardware onboard.
HTH!
Hi,
Thanks for your reply.
I used 2 PSUs with one 20 pin connector each, an E-5 2660 V3 Xeon with an Arctic Freezer i30 CO cooler and 8GB of corsair memory. It doesn’t power on! Any ideas?
Thanks!
I’m afraid not. Apart from my earlier suggestion of exploring the system via IPMI, it should have a method to boot it remotely. But only if all requirements are fulfilled and I have no idea what they are.
PS: in case you don’t know: IPMI is the onboard management system, it works independently from the main system and should power up when power is connected. You should be able to access it via the IPMI port, i.e. the network. Give it a few minutes after powering up, 5 mins should usually be enough to be able to connect.
Thanks Dutch Master. I know what an IPMI is, I have many servers in service.
I just haven’t had any experience with blade boards.
The thing gets no power, hence I can’t access any IPMI services.
Stumbled upon that too. Not much help there, hence why I’m asking on level1techs.
Got this working. For the record, it requires an enterprise PSU and the ASUS power board to go with it. It also needs the smart psu monitoring cables connected.
These weird boards are used by proprietary, high-frequency trading servers, such as the Ciara ORION HF330-G3.
I finally got life into mine today.
Using i7-5820k
16gb hypertec ddr4
Original PSU .
Looks complete mess at the moment with wrong fans but it works
If you plan to use without IPMI you will need a pci riser as the GPU will be blocked buy some small capacitors
a
Indeed mine was also from the same outlet Slow going to get information from asus they have helped to some extent and more information maybe on the way regarding the pinouts enable disabled as not all are clearly marked.
Noice! Well done Scififreaks. I’m curious: are you using an original Asus Power distribution board? If not, what are you using that is compatible? I’m looking to source a spare.
EDIT: I can see in the pictures that the power distribution board is Asus-branded.
Good morning i puchased the psu and got the pdb with it from [Compuware Cpr-1621-1M21 www. ebay. co. uk
/ itm/325552558872
The distribution board is not labled very well on g oogle
But my photos may help
Morning!
I have one of these boards too. Have you connected SATA power to it?
Not yet i have nvme .
cd player via usb.
Working slowly on this board.
I have an nvme on mine too. You mentioned Asus support helped a little bit. What help were they able to provide?
This pci bracket was sent which was a bonus.
I didn’t get black cables for these cables only the 20 pin atx which has the pmbus gpu and atx12v cbles all running of the 20 pin.
First they referenced the x99 ws/ipmi
For same chipset first they mentioned type of ram and cpu which i also found in the link they directly linked me to an updated page that keeps resetting so refreshing to continue download.
Comparison of old and new look identically the same except the Chinese part but no further information in that manual.
The main list is of importance of compatible cpu gpu ram network adapters ssd sata drives.
Windows Server 2008 R2
Windows Server 2008 R2 SP1
Windows Server 2012
Windows Server 2012 R2
Windows 7 SP1
Windows 8
Windows [8.1/64) bit
Windows [10/64) bit
RHEL (Server)
RHEL 5.10
RHEL 5.11
RHEL 6.5
RHEL 6.6
RHEL 7.0
RHEL 7.1
RHEL 7.2
SUSE Linux Enterprise Server 11 SP3
SUSE Linux Enterprise Server 12
SUSE Linux Enterprise Server 12 SP1
SUSE Linux Enterprise Desktop 11 SP3
SUSE Linux Enterprise Desktop 12 SP1
CentOS
CentOS 5.10
CentOS 5.11
CentOS 6.4
CentOS 6.5
CentOS 6.6
CentOS 7.0
CentOS 7.1
Ubuntu
Ubuntu 13.10 (EOL)
Ubuntu 14.10 (EOL)
Ubuntu 16.04
CPU E5‐1600 v3
E5-1680 V3
8C/20M/140W/DDR4 2133/Turbo/HT 140W
CPU E5‐1600 v3
E5-1660 V3
CPU E5‐1600 v3
E5-1650 V3
6C/15M/140W/DDR4 2133/Turbo/HT 140W
CPU E5‐1600 v3
E5-1630 V3
4C/10M/140W/DDR4 2133/Turbo/HT 140W
CPU E5‐1600 v3
E5-1620 V3
CPU E5‐1600 v4
E5-1680 V4
CPU E5‐2600 v3 E5‐2699V3 18C/45M/145W/DDR4 2133/9.6GT/Turbo/HT 145W
CPU E5‐2600 v3 E5‐2698V3 16C/40M/135W/DDR4 2133/9.6GT/Turbo/HT 135W
CPU E5‐2600 v3 E5‐2697V3 14C/35M/145W/DDR4 2133/9.6GT/Turbo MAX /HT 145W
CPU E5‐2600 v3 E5‐2695V3 14C/35M/120W/DDR4 2133/9.6GT/Turbo MAX/HT 120W
CPU E5‐2600 v3 E5‐2683V3 14C/35M/120W/DDR4 2133/9.6GT/Turbo MAX/HT 120W
CPU E5‐2600 v3 E5‐2690V3 12C/30M/135W/DDR4 2133/9.6GT/Turbo/HT 135W
CPU E5‐2600 v3 E5‐2680V3 12C/30M/120W/DDR4 2133/9.6GT/Turbo/HT 120W
CPU E5‐2600 v3 E5‐2670V3 12C/30M/120W/DDR4 2133/9.6GT/Turbo/HT 120W
CPU E5‐2600 v3 E5‐2660V3 10C/25M/105W/DDR4 2133/9.6GT/Turbo/HT 105W
CPU E5‐2600 v3 E5‐2650V3 10C/25M/105W/DDR4 2133/9.6GT/Turbo/HT 105W
CPU E5‐2600 v3 E5‐2640V3 8C/20M/90W/DDR4 1866/8.0GT/Turbo/HT 90W
CPU E5‐2600 v3 E5‐2630V3 8C/20M/85W/DDR4 1866/8.0GT/Turbo/HT 85W
CPU E5‐2600 v3 E5‐2620V3 6C/15M/85W/DDR4 1866/8.0GT/Turbo/HT 85W
CPU E5‐2600 v3 E5‐2609V3 6C/15M/85W/DDR4 1600/6.4GT 85W
CPU E5‐2600 v3 E5‐2603V3 6C/15M/85W/DDR4 1600/6.4GT 85W
CPU E5‐2600 v3 E5‐2650LV3 12C/30M/65W/DDR4 2133/9.6GT/Turbo/HT 65W
CPU E5‐2600 v3 E5‐2630LV3 8C/20M/55W/DDR4 1866/8.0GT/Turbo/HT 55W
CPU E5‐2600 v3 E5‐2667V3 8C/20M/135W/DDR4 2133/9.6GT/Turbo MAX /HT 135W
CPU E5‐2600 v3 E5‐2643V3 6C/20M/135W/DDR4 2133/9.6GT/Turbo MAX /HT 135W
CPU E5‐2600 v3 E5‐2637V3 4C/15M/135W/DDR4 2133/9.6GT/Turbo MAX /HT 135W
CPU E5‐2600 v3 E5‐2623V3 4C/10M/105W/DDR4 1866/8.0GT/Turbo/HT 105W
CPU E5‐2600 v3 E5‐2687WV3 10C/25M/160W/DDR4 2133/9.6GT/Turbo MAX /HT 160W
CPU E5‐2600 v4 E5‐2699V4 22C/55M/DDR4 2400/9.6GT/Turbo/HT 145W
CPU E5‐2600 v4 E5‐2603V4 6C/15M/DDR4 2400/6.4GT/Turbo/HT 85W
i7‐5820K
i7‐5930K
i7‐5960X
i7‐6800K
i7‐6900K
i7‐6950X
i7‐6850K
DDR4 RDIMM 2400 M393A4K40BB1‐CRC
DDR4 2400 RDIMM 32GB 288P , 20nm_8Gb_B‐die(IDT/MTG, 2Rx4)
Samsung
DDR4 RDIMM 2400 M393A2K40BB1‐CRC
DDR4 2400 RDIMM 16GB 288P, 20nm_8Gb_B‐die(IDT/MTG, 2Rx4)
Samsung
DDR4 RDIMM AD4R2133W4G15‐BMIA DDR4 2133 RDIMM 4GB 288P ADATA
DDR4 RDIMM 75.CA3G0.G000B (M393A1G40DB0‐CPB) DDR4 2133 RDIMM 8GB 288P APACER
DDR4 RDIMM MTA18ASF1G72PZ‐2G1A2 DDR4 2133 RDIMM 8GB 288P Micron
DDR4 RDIMM HMA41GR7MFR4N‐TF DDR4 2133 RDIMM 8GB 288P Hynix
DDR4 RDIMM M393A2G40DB0‐CPB DDR4 2133 RDIMM 16GB 288P Samsung
DDR4 RDIMM MTA36ASF2G72PZ‐2G1A2 DDR4 2133 RDIMM 16GB 288P Micron
DDR4 RDIMM HMA42GR7MFR4N‐TF DDR4 2133 RDIMM 16GB 288P Hynix
DDR4 RDIMM M386A4G40DM0‐CPB DDR4‐2133 LR‐DIMM 32GB 288P Samsung
DDR4 UDIMM 78.B1GM4.AF00B DDR4 2133 ECC DIMM APACER
DDR4 UDIMM M391A2K43BB1‐CPB00 DDR4 2133 ECC DIMM Samsung
DDR4 UDIMM HMA451U7AFR8N‐TF DDR4 2133 ECC DIMM SKHynix
DDR4 UDIMM HMA41GU7AFR8N‐TF DDR4 2133 ECC DIMM SKHynix
DDR4 UDIMM HMA82GU7MFR8N‐TF DDR4 2133 ECC DIMM SKHynix
DDR4 UDIMM MTA9ASF51272AZ‐2G1A1 DDR4 2133 ECC DIMM Micron
DDR4 UDIMM M391A2K43BB1‐CPB00MTA18ASF1G72AZ‐2G1A1 DDR4 2133 ECC DIMM Micron
M.2 (NGFF) APM2T42A100016GD‐BTM M.2 T42 A100‐M 16GB 16384Mx8 APACER
M.2 (NGFF) APM2T42A100032GD‐BTM M.2 T42 A100‐M 32GB 16384Mx8 APACER
M.2 (NGFF) APM2T42A100064GD‐BTM M.2 T42 A100‐M 64GB 32768Mx8 APACER
M.2 (NGFF) APM2T42A100128GD‐BTM M.2 T42 A100‐M 128GB 65536Mx8 APACER
3.5" SAS ST3600057SS 3.5" SAS2 HDD 600G /6Gb/15K rpm Seagate
3.5" SAS ST3300657SS 3.5" SAS2 HDD 300G / 6Gb/15K rpm Seagate
3.5" SAS ST4000NM0023 3.5’ SAS HDD 4TB 7200RPM (NS) Seagate
3.5" SAS ST3000NM0023 3.5’ SAS HDD 3TB 7200RPM (NS) Seagate
3.5" SAS ST2000NM0023 3.5’ SAS HDD 2TB 7200RPM (NS) Seagate
3.5" SAS ST1000NM0023 3.5’ SAS HDD 1TB 7200RPM (NS) Seagate
3.5" SAS ST6000NM0014
3.5’ SAS 12Gb HDD 6TB 7200RPM (NS) 4KN
Seagate
3.5" SAS
ST6000NM0034
3.5’ SAS 12Gb HDD 6TB 7200RPM (NS) Seagate
3.5" SATA (DP
ST3000DM001 SATA3 GRENADABP2 Refresh 3TB 7200R 3.5” SEAGATE/ST3000DM001/CC26 Seagate
3.5" SATA (DP
ST2000DM001 SATA3 GRENADABP 2TB 7200R 3.5” SEAGATE/ST2000DM001/CC26 Seagate
3.5" SATA (DP
ST1000DM003 SATA3 PHARAOH OASIS 2TB 7200R 3.5” Seagate
3.5" SATA (DP
ST2000DM001 SATA3 BP2.0 2TB 7200R 3.5’ 4K Seagate
3.5" SATA
(DP
ST1000DM003 SATA3 BP2.0 1TB 7200R 3.5’ 4K Seagate
3.5" SATA (Enterprise) ST6000NM0024 3.5’ SATA3 HDD 6TB 7200RPM (NS) Seagate
3.5" SATA (Enterprise) ST4000NM0033 3.5’ SATA3 HDD 4TB 7200RPM (NS) Seagate
3.5" SATA (Enterprise) ST3000NM0033 3.5’ SATA3 HDD 3TB 7200RPM (NS) Seagate
3.5" SATA (Enterprise) ST2000NM0033 3.5’ SATA3 HDD 2TB 7200RPM (NS) Seagate
3.5" SATA (Enterprise) ST1000NM0033 3.5’ SATA3 HDD 1TB 7200RPM (NS) Seagate
3.5" SATA MG04ACA400A 3.5" SATA3 HDD 4TB 6G 7200PRM 4Kn Toshiba
3.5" SATA (Enterprise) ST6000NM0024 (1HT17Z‐001) 3.5" SATA3 HDD 6TB 6G 7200PRM Makara/NS Seagate
2.5" SAS ST1200MM0007 2.5" SAS 10K.6 HDD 10KRPM 1.2TB /6Gb Seagate
2.5" SAS ST900MM0006 2.5" SAS 10K.6 HDD 10KRPM 900G / 6Gb Seagate
2.5" SAS ST600MM0006 2.5" SAS 10K.6 HDD 10KRPM 600G / 6Gb Seagate
2.5" SAS ST300MM0006 2.5" SAS 10K.6 HDD 10KRPM 300G /6Gb Seagate
2.5" SAS ST2000NX0273 2.5" SAS HDD 7200RPM 2TB / Seagate /12Gb Seagate
2.5" SAS ST1800MM0128 2.5" SAS HDD 10KRPM 1.8TB / Seagate/12Gb (Turbo Cache) Seagate
2.5" SAS ST1800MM0018 2.5" SAS HDD 10KRPM 1.8TB / Seagate/12Gb (Non Turbo Cache) Seagate
2.5" SAS ST600MP0035 2.5" SAS HDD 15KRPM 600G / Seagate/12Gb Seagate
2.5" SAS ST300MP0035 2.5" SAS HDD 15KRPM 300G / Seagate/12Gb Seagate
2.5" SATA
ST2000NX0253 2.5" SATA3 HDD 2TB 7200RPM
Seagate
2.5" SATA
ST9500620NS 2.5’ SATA3 HDD 500GB 7200RPM
Seagate
2.5" SATA
ST91000640NS 2.5’ SATA3 HDD 1TB 7200RPM
Seagate
2.5" SATA
ST2000NX0243 4KN 2.5" SATA3 HDD 2TB 7200rpm/Seagate Seagate
2.5" SSD SATA INTEL/SSDSC2BW120A401 SSD 530 SERIES 120GB 2.5’ MLC INTEL
2.5" SSD SATA ASP600S7‐64GM‐B SATA SSD 64GB 2.5’ MLC 7.0MM Apacer
2.5" SSD SATA ASP600S7‐128GM‐B SSD SATA 2.5’ MLC 128GB 7.0MM Apacer
PIKE PIKE2108‐32PD PCIe2 / SAS6G / 6.44 in x 1.57 in (1U compatible)
PIKE II PIKE II 3008‐8i Standard PCIe interface / PCIe3 / SAS12G / 5.81 in x 2.71 in (147.65 mm X 68.9mm)
PIKE II PIKE II 3008‐4i4e Standard PCIe interface / PCIe3 / SAS12G / 5.81 in x 2.71 in (147.65 mm X 68.9mm)
PIKE II PIKE II 3108‐8i/16PD Standard PCIe interface / PCIe3 / SAS12G / Standard low profile
RAID Card‐LSI MegaRAID SAS 9271‐8i PCIe3 / SAS6G / MD2 Low profile (6.6" x 2.536")
RAID Card‐LSI MegaRAID SAS 9280‐8e PCIe2 / SAS6G / MD2 Low profile (6.6" x 2.536")
RAID Card‐LSI MegaRAID SAS 9260‐8i PCIe2 / SAS6G / MD2 Low profile (6.6" x 2.536")
RAID Card‐LSI MegaRAID SAS 9240‐8i PCIe2 / SAS6G / Low profile (6.6" x 2.536")
RAID Card‐LSI MegaRAID SAS 9217 4i4e PCIe2 / SAS6G / Low profile (2.6” x 6.6”)
RAID Card‐LSI MegaRAID SAS 9361‐8i PCIe3 / SAS12G / 6.6" x 2.536" (Low‐Profile)
RAID Card‐LSI MegaRAID SAS 9341‐8i PCIe3 / SAS12G / 6.6" x 2.536" (Low‐Profile)
RAID Card‐Adaptec 6805 PCIe2 / SAS6G / 2.5" H x 6.6" L (64mm x 167mm)Low‐Profile MD2
RAID Card‐Adaptec 6445 PCIe2 / SAS6G / 2.5" H x 6.6" L (64mm x 167mm)Low‐Profile MD2
RAID Card‐Adaptec 8885 PCIe3 / SAS12G / 2.535"H x 6.6"L (64mm x 167mm)MD2‐Low Profile
Network
Networking Card PEB‐10G/57840‐2S PCI‐E Gen3 x8 / 4.72”x 1.77”(Lower Than Low‐profile)
Networking Card PEB‐10G/57811‐1S PCI‐E Gen2 x8 / 4.72”x 1.77”(Lower Than Low‐profile)
Networking Card Intel(R) Ethernet Server Adapter X540‐T2 PCI‐E Gen2 x8 / Low‐profile
Networking Card Intel(R) Ethernet Server Adapter I350‐T2 PCI‐E Gen2 x4 / Low‐profile
Networking Card Intel(R) Ethernet Converged Network Adapter X520‐DA2 PCI‐E Gen2 x8 / Low‐profile
Networking Card Intel(R) Ethernet Converged Network Adapter X520‐QDA1 PCI‐E Gen2 x8 / Low‐profile
Infiniband HBA PEM‐FDR PCI‐E Gen3 x8 / 4.72”x 1.77”(Lower Than Low‐profile)
Infiniband HBA‐ Mellanox MCX353A‐FCBT (CX3) PCI‐E Gen3 x8 / 14.2cm x 5.2cm
Infiniband HBA‐ Qlogic QLE7342 PCI‐E Gen2 x8 / 12.08 cm x 1.84 cm
GPU
GPU nvidia Quadro K6000 PCI‐E Gen3/Active/Dual Slot/266.7x111.2mm 225W
GPU nvidia Quadro K5200 PCI‐E Gen3/Active/Dual Slot/266.7x111.2mm 150W
GPU nvidia Quadro K4200 PCI‐E Gen2/Active/Single Slot/241.3x111.2mm 110W
GPU nvidia Quadro K2200 PCI‐E Gen2/Active/Single Slot/202.4x111.2mm 75W
GPU nvidia Quadro K620 PCI‐E Gen2/Active/Single Slot/160x68.9mm 45W
GPU nvidia Quadro K420 PCI‐E Gen2/Active/Single Slot/160x69.9mm 41W
GPU(Gaming) nVidia Geforce GTX980‐4GD5
Unofficial but works Amd Firepro V5900
Sorry for delay iwas editing the compatability list.
I also tried desktop atx didn’t work. They use server psu layouts
This pic will show 12v cables
I hope this helps I have used up my 3 replies apparently that’s why ive added to this post.
Hi, I made the same observation in my earlier posts in this thread: it needs a server PSU with the Asus power board and the SMART sense connected to start. Indeed, a desktop PSU won’t work.
Now I’m looking for a compatible rackmountable case for this board. Sourcing an original case doesn’t seem feasible at this time, so if anyone finds one that can house this board, please let me know.
