Blackmagic Design Intensity Shuttle for USB 3.0 not Working
Few months ago I bought Blackmagic Design Intensity Shuttle for USB 3.0 not Working
http://www.amazon.com/Blackmagic-Design-Intensity-Computers-Professional/dp/B003WSQTWU
But the problem is it do not works it shows black screen in softwere, just audio works.
After lot of hours of recherche, I found out, that it just works on
NEC / Renesas USB 3.0 chipsets.
So I understand, that i need to buy PCI Express USB 3.0.
And my question is will Blackmagic Design Intensity Shuttle for USB 3.0 work with this  PCI Express USB 3.0
--> http://www.ebay.com/itm/SEDNA-PCI-Express-USB-3-0-4-Port-Adapter-4E-NEC-Renesas-720201-chip-set-/200953846145?pt=US_Internal_Port_Expansion_Cards&hash=item2ec9c85981
Or you maybe can suggest to me, something, else, and maybe someone else also had such problem and how did you resolve it?
Thanks in advance!
That expansion card should work!
Ok, wish me luck! I will go and order it ;)
Thanks!
