Blacklist/Ubisoft rant
I am seriously having a shitty computer week. I bought a new hard drive that was dead out of the box, but on top of that, my $60 game that I bought wont even run. I bought blacklist last week because I really like the splintercell games. I bought it on uplay, not steam, which was my first problem. But on top of that, It wont even launch the game. It will crash on the first loading screen. I thought maybe the files were corrupt or something, and Uplay doesnt even have a verify files option. So I had to completely re download and install the 20gb game. Once again, it doesnt work, and it wont even launch the game. Ok. What the hell. So I looked it up online and tried every single fix I could find. I reinstalled my drivers, the game, and tweaked every .ini setting possible but with no fix. So I called Ubisoft to ask them what the hell. They told me they are working on it but im basically SOL until they can fix, and refunding isnt an option. They also told me to reinstall it on my C: drive because that fixed it for some people. So I downloaded it for the FOURTH time and what do you know, it didnt work. So now im out of 60 bucks with a game that I cant even play. Seriously frustrating.
I would contact them and tell them that there is a problem and try to return it. then buy from another vendor like steam... I hate buy directly from the vendors. The purpose of that is to get a discount, and they never give discounts so what is the point.
Sorry that happened man. They will probably get it working through a patch in the near future. You might have to reinstall it or something after they fix it.
I bought the game in Steam but it launches through UPLAY. I think it even made a UPLAY account for me automatically. Anyway, the game still crashed as soon as I got to the second cut scene (the one with the martyrdom guy). Tomb Raider had similar problems when that launched (it was caused by the NVidia drivers) and it took them, NVidia, a long time before they fixed it. I haven’t started troubleshooting yet, but will come back if I find a fix. For Tomb Raider you had to uncheck “Exclusive fullscreen”.
This might help you launch the game:
http://www.crashwiki.com/splinter-cell-blacklist-pc-crashes-blackscreen-freezes-gamepad-issues-change-resolution-blacklist-service-unavailable/
I found a fix:
Go to C:\Users\Ola\Documents\Ubisoft\Blacklist\videoSettings.ini
If you have problems with launching the game:
Channge the variable "WindowStyleFinal=" to 0 or 2. 0 for Windowed, 1 for fullscreen and 2 for windowed fullscreen.
If you have problems with the game crashing:
Change the variable "StartupGraphicsApi=" from 5 to 4.
If you have problems with preformance:
Check the "gpuFamily=", if it is set to the onboard graphics you have to change it in the Nvidia control panel.
If you got the game on UPLAY you could need a patch v1.01: https://support.ubi.com/en-US/FAQ.aspx?platformid=9&brandid=249&productid=2732&faqid=kA030000000eZTxCAM
ive done all of these, plus some and still none. But thanks anyways.
