Black screen on higher than 60fps
KVM Model:
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer
10Gbps
Problem:
My KVM has been working fine for a few months. Today after switching between PC, one of the screen stayed black (3440x1440@175Hz ). I tried different things but nothing got it back on until I realised it would work if I switched the refresh rate to 60fps (doesn’t even work at 120fps). I have tried DDU, reinstalled NVIDIA driver, unplugged everything and power cycled the KVM, tried different cables… Nothing seems to get it back working for anything > 60fps.
For cables, I’m using fibbr 1m.
Try eliminating some variables. Unplug everything and only plug back in 1 hdmi input and hdmi output, then plug in the power supply. Do you have other cables to try? The fibbr cable could be faulty
What’s the other monitor resolution and refresh rate that didn’t stay black? Can you get a video to better show us?
I tried all cables that I have available (6 different HDMI2.1 cables all <2m).
The other monitor is just 4k 60fps.
Did you go through these steps?
Yeah it’s the same. I will try and record a video tomorrow.
So nothing seems to be working. Is there any internal memory of the KVM that I can reset apart from just unplugging everything? I tried changing to club3d cables, still the same.
Not sure what’s there to even record, it just turns off when refresh rate is changed to anything higher than 60.
I gotcha, email “wendell at level1techs dot com” for further technical support and potential replacement
