Black PBT keycaps (blank, side printed or laster etched)
Hi, I have a Filco tkl board, I want to replace the keycaps.
Problem, no one bloody sells PBT keycaps (in Canada) and those who do have the capslock key with a translucent LED slot. So where do you guys suggest I buy some? Ebay hasn't yielded any results and tiger imports is all out of stock/not going to restock the ducky blanks
Check through these, they should have what you are looking for somewhere. http://www.reddit.com/r/MechanicalKeyboards/wiki/keycapsellers
I already did, I've been hunting for keycap for a while.
I've found 3 possible candidates two of which are out of stock everywhere and the 3rd is half out of stock
