Alright. So i'll make this as clear as possible.
I recently had problems with fedora 21 where the boot menu would show up. I'd select which version of fedora i wanted to use and then i would be greeted by a black screen where the lock screen should be. I can't acces any form of command line either so i was stumped. And after reading through tons of threads online i did not get any wiser..
So i did what any desperate man would do. i fappe..Ehm I re-installed fedora. Forsaking any of the files i had on my previous installation. And after updating, installing the gnome tweak tool, yum extender, gnome shell extensions, enabled rpmfusion, updated again, vlc, fastest mirror plugin, flash player, chrome, fedy tool, virtualbox, gnome music player, And the driver that worked the last few times which was the "newer geforce" drivers from the rpmfusion site.
Then i watched some youtube videos and hung around on some forums before turning my pc off.
.. The problem is back.. I can press c to bring up some form of command line in the boot menu but thats about it.
Any suggestions as to how to fix this.
Or if you noticed a major screwup Salutes that would cause this. Feel free to point it out to me..
I was just playing a game on windows and it auto updated.. I need to get back to linux!
Edit: forgot to add specs
cpu: 3770k
motherboard: asrock pro4
gpu: asus 780 strix
Thanks in advance.
Techswede
