Black and orange fans
I am trying to find some good fans that are black and orange. They need to be 140mm.
The only ones I have found so far are these:
 http://www.overclockers.co.uk/showproduct.php?prodid=FG-008-AL&groupid=701&catid=2331&subcat=1816
I am going to be using the fans on this cpu cooler :
http://www.overclockers.co.uk/showproduct.php?prodid=HS-061-ZA
If anyone can suggest any better fans or if these are decent and I should just stick with them? Also curious if any has used the cooler and what the think about it.
Thanks in advance
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=140%20mm%20fan&bop=And&SrchInDesc=orange&Page=1&PageSize=20
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=node%3D430499031&field-keywords=orange+140mm+fan&rh=n%3A340831031%2Cn%3A428655031%2Cn%3A430499031%2Ck%3Aorange+140mm+fan
don't know why but they left these out of the search..
http://www.amazon.co.uk/Compucase-CF-V14S-Bearing-MTBF150-Silence/dp/B0050TRLUS/ref=sr_1_5?s=computers&ie=UTF8&qid=1386008549&sr=1-5&keywords=cougar+fanteksynd-21
http://www.amazon.co.uk/Thermalright-TY-143-140-Cooling/dp/B009QGHQ1K/ref=sr_1_25?s=computers&ie=UTF8&qid=1386008912&sr=1-25&keywords=140mm+fan
If you buy from amazon don't forget the affiliate code teksynd-21
Nice one, thanks. Are there any brands in particular to go for ? I know the noctua fans are meant to be really good but the colour doesn't fit.
I really like the look of this fan you found : http://www.amazon.co.uk/Compucase-CF-V14S-Bearing-MTBF150-Silence/dp/B0050TRLUS/ref=sr_1_5?s=computers&ie=UTF8&qid=1386008549&sr=1-5&keywords=cougar+fanteksynd-21
Sorry if these are really noob like questions but the more websites I go to, to found out about computer parts the more contradicting information I get. I trust the tek syndicate forums. What are the most important features to look for in a fan ? Things like max speed ? Air flow ? Air pressure ? Bearing types ?
I really don't know, I am a noob as well I just look at the cfm and static pressure..Oh yeah and pin connectors to see if I need adapters..
I have gone for http://www.amazon.co.uk/gp/product/B0050TRLK8/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1
It looks the same as one you suggested but has slightly higher specs. They one have to last 6 to 8 months until I water cool but I was hoping to do a little overclocking with air before the switch so hopefully these fans and the new heat sink do the job
Thanks for the help NonServian
Yeah that looks better than the other, and only 1dollar/pound/euro/whatever more for twice the life span..
