Bitrate dilemma
I just purchased a new capture card. There are plenty of bitrates, but it seems that 60.0Mbps is the max bitrate I can chose. The quality of that is fine, but anything lower starts to degrade quite noticeably. I've look at other peoples videos using the same capture card, same bitrate and resolution and theirs seems to be so much better quality compared to mine with 20.0Mbps 1080p. Even with mine uploaded RAW with no rendering.
I noticed if I do render one of my videos from original bitrate 60.0Mbps at 1080p, through Sony Vegas rendering down to 25,999,360 Sony AVC 1080p, it looks just the same as the RAW file. Why is it that if I record a video at 30.0Mbps, it's not even close to the quality as a rendered video from 60.0Mbps to 20.0Mbps from Sony Vegas?
The capture card is an Avermedia C985 Live Gamer HD. Not sure if it's a faulty card, or software issue. I've reinstalled the drivers and software a few times now and nothing changes. Even if I record at 720p 20.0Mbps, it's still bad quality just as if it were 1080p 20.0Mbps. here's a sample.
http://www.youtube.com/watch?v=CJ_cDSuA1Ik&feature
When you record something and then down convert it, it always will look better than recording it at the 2nd quality level to begin with.   But it shouldn't be too terribly noticeable.  It could be a driver issue.
