well; That's how it arrived.
The BitForce Jalapeno from ButterflyLabs was dubbed as the most 'cost effective' one. At least at that time. It arrived about 7 months late(r) so you'll have to excuse me if I'm not up to date.
At unpacking I stumbled upon 1 minor hickup;
A 2 phase powercord that ends in an american plug. I'm from Belgium, damnit. Luckily I have loads of those (with an european plug, I thank you) lying around, so I could get to testing immediately.
So, when connecting the USB and the Power, it booted up pretty fast and.. if you watch the video, the fan really makes alot of noise, Yes, thats a -1. I hope I can retrofit the fan in the future, But first ill have to find out if that's even a good idea. When mining it DOES become very hot in there. Also, the order was delayed because of 'thermal' issues. I'm pretty sure they replaced the fan with some kind of delta fan to get rid of the heat....
When Windows finds the device, it automaticly installs the serial driver. there's no need to manually do that, so no time wasted there. You will however need software to use the device, after connecting to the correct COM port. (like most serial devices, Duh)
This seemed to have happened automaticly. For instance, mine was on COM port 54. The software didn't even ask me for that.
Anyho this is how the butterfly software looks like: (you may click to enlarge)
The next logical step is to insert pooldata, And get it mining asap!
The included binary (BFGMiner) has stratum support. Well ofcourse it does, but just saying :-) . There is also a provided CGMiner binary, but I'm using BFGMiner for better results. (So yup, you can also use a custom binary, no worries there). After adding the pool data 'manually' (it only has a couple of preset pools, mine wasn't in them) from the binary and commandline (Something you should be familiar with when mining); Theres only one thing left, Mine my minion, MINE!
It sets off with 5.83Ghz. The log of the client (3th tab) is always going bezerk with information; You could find errors there aswell if something goes wrong. (also not uncommon with miners). Theres also a red indicator LED telling you its actually doing alot of math or not.
Thats pretty much it. At the end of writing this blog I can tell you however the device is becoming hot. But with an advertised Gigahash of 4.5, and a practical Gigahash of 5.8+, I am not complaining. It does explain the overly eager fan though.
EDIT: I don't have a wattmeter here, I'll update the facts when I get home.
