Hey Guys!
This is my first time building a PC and i really love the form factor of the BitFenix Prodigy.
I have around a $600 budget but feel free to go maybe 20-30 over if it's worth it.
I would really appreaciate the help! :D
Thanks!
Hey Guys!
Thanks!
Thats not a lot for a m-itx BitFenix Prodigy build what are you going to use it for gameing,web browseing,media box,video work?
http://pcpartpicker.com/p/TYMI
CPU: Intel Core i3-2120 3.3GHz Dual-Core Processor ($109.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H61N-USB3 Mini ITX LGA1155 Motherboard ($73.98 @ Outlet PC)
Memory: Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1600 Memory ($47.98 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($69.98 @ Outlet PC)
Video Card: HIS Radeon HD 7850 1GB Video Card ($154.69 @ Amazon)
Case: BitFenix Prodigy (White) Mini ITX Tower Case ($79.99 @ NCIX US)
Power Supply: Corsair CX 430W 80 PLUS Bronze Certified ATX12V Power Supply ($39.99 @ Newegg)
Total: $576.60 (After rebates) $596.60 (Before rebates)
AMD APU with crossfire (HD6670)
http://pcpartpicker.com/p/TYRN
CPU: AMD A10-5700 3.4GHz Quad-Core Processor ($119.99 @ NCIX US)
Motherboard: ASRock FM2A85X-ITX Mini ITX FM2 Motherboard ($103.98 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Disk ($101.99 @ Newegg)
Storage: Hitachi 500GB 3.5" 7200RPM Internal Hard Drive ($56.98 @ Outlet PC)
Video Card: PowerColor Radeon HD 6670 1GB Video Card ($44.99 @ Newegg)
Total: $595.89 (after rebates) $611.90(before rebates)
crossfire 6670's pale in comparison to the 7850, imo, and the a-10 is slower and consumes more power than the i3.
My build is somewhat identical to your first build.
http://pcpartpicker.com/p/Sgul
Went slightly over budget but I think its okay. If you want to go under 600, just go with any 1gb vram version of the 7850.
If you don't mind another $17 over budget you can get a sapphire 7870 ghz edition which is in my opinion a very good step up for only $17.
Mostly gaming and some web browsing
