Bitcoinplus.com?
My computer is terrible so i wont be mining anytime soon but im interested in bitcoins but i found this website and i wanna know if it actually really works.
So ill just drop my link down here just because i can.
http://www.bitcoinplus.com/generate?for=26916363
Yes I posted some information in some previous threads about this site, it basically allows you to mine with your CPU on a webpage. It is quite handy as there is no setup required, however since it is mining with your CPU and is allocated 'low priority' on your system it will take a while to generate a whole BitCoin. I've done the math and unless you have a group of people mining on the site for you it will take you quite a long time.
A long time translates to 6 months to 10 years depending on your luck.
