I recently tried to set up a bitcoin wallet using Bitcoin QT, after everything had synced up it was using about 90% of my CPU (Specs below) after this and trying to do basic tasks it took over and nothing at all would work, I decided to uninstall but now my computer is still ridiculously slow, even firefox can't open a new tab without dying.
That's really weird, i haven't heard of that happening to anyone else. I highly doubt that it was bitcoin-qt.
You probably have some sort of virus or something. Run a full computer scan and see if that shows anything. Also, upload a photo of your 'processes' tab in task mamager because often there's a weird program or something that just lurks in the background gobbling up your cpu power.
Ran a full system scan using AVG, nothing there to report. when I'm doing nothing its fine but when I click anything it dies. I've ordered a new 1TB external drive so I'm going to back up and reinstall windows. Thanks again for contributing.
Thanks for the suggestion but I uninstalled the program and it seems to have taken everyfile with it to the grave. Any ideas if their under any name I might miss?
I've googled this problem to death, I wouldn't normally ask this sort of question on the forum but I've yet to find anyone with a similar problem. The only problems arising seem to be for linux which isnt helpful as I installed it on my win 7 comp.
Here if i can sort through our main forum I will find our mumble server and you can hop on and talk to people their who are very smart. Just give me a little.
Thanks Dr.Jetix, I had missed deleting the appdata as I looked in the wrong place, it was about 8gb and I've taken that away and ran my BIOS updater as this should replace any old faults with the board. I will update when I have the chance. Lets hope this fixes it!
