I was looking at the I7 4820K on PcPartPicker and when i combined the bio star with the cpu it said "Some Intel X79 chipset motherboards may need a BIOS update prior to using Ivy Bridge-E CPUs." and i was wondering if any one had these to components or knows if this will effect anything major.
well biostar is mostly not the best quality of boards, i have no idea if that board supports ivy-e out of the box, but i personaly think that it will need a bios update.
Anyway i would personaly buy a better board, if i was you.
Also unless you're going to be using a 6 core I7 or lots of graphics cards, socket 2011 isn't really a smart choice.
