Bios is not working please help!
Ok so I built my first computer, YAY!!! But, when I was looking thru the BIOS I accidently set the SSD as the primary boot device. Now when I boot it up the ASUS Logo shows up and says "Press Delete to enter the BIOS" I  click delete and it some text shows up saying nothing is booting. I try to get into the BIOS so I can boot from my Windows 7 install USB, but I can't get into the BIOS by pressing delete. PLEASE HELP!
first off, turn it off, unplug it and push the power button for ten seconds, then plug it back in again. if that doesn't work let us know.
reset the bios
there should be a jumper for it or you can unplug it and remove the battery for 15 min
If I remove the battery will I break anything ???
Take me out for 10mins!
I know where it is...
sorry for trying to help.......you would be surprised what people who try and build a PC dont know.
