Hello all. I have a question regarding BIOS fan control. I have a ASUS Z87-A and i recently got some noctua fan's to put in the front of my case and on the side. I went into my bios to control them (i was just going to leave them as is but when i started up my PC after putting the fans in they were a bit to loud). I went to the "monitor" section of my bios where the fan control is. How it works in my bios is a minimum temp and a percentage and a maximum temp and a percentage, as shown in this video: https://www.youtube.com/watch?v=9I1b8v3jSZs
The issue im having though is the lowest i can set it to is 60%, any lower and i get "invalid input range", 60% results in the fans running at 1400RPM-1500RPM which is a bit to loud (its also confusing because they are 2000RPM fans so 60% should translate to 1200 RPM).
I tried using AI Suite to lower the fan speed via the fan software in it and i was successful. I was able to lower it to 40% which translated out to 800 RPM, but i would rather have this set via BIOS because i dont particularly like having programs and process's on my computer that arent completly needed.
I have the latest BIOS on my motherboard aswell.
