First, I was unsure if this should be placed in the Mobo, case, or fan section of the forums, if this is in the wrong section I sincerely apologize.
This is my current case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087
All of the fans are 3 pin connectors with manual controls on the fan itself (the front fans have a little knob to twist and the top/rear fans have a switch for hi/low). I know that the Z87 boards support both PWM and voltage controls for fans, but are they able to control fans that have manual controls on them?
Granted I could simply control my fans manually but I would very much like to utilize the fan controls as opposed to have them running at a constant speed even when Unnecessary.
Please and thank you for any insight!
