EDIT: Updated Parts List
It’s been a good many years since I last built a new PC, but my old GTX 1080 just died on me and forced my hand. Time to build a new one.
First version Prospective Parts List: 2025 Gaming - AMD Ryzen 7 9800X3D, Radeon RX 9070 XT, Lian Li A3-mATX MicroATX Mini Tower - PCPartPicker
In the past I have been on team Intel and nVidia, but I get the feeling the winds are changing of late. EVGA was my go-to for graphics cards so I was devastated to see they’d left the market. I figure I might as well switch teams and try an AMD build this time. I’ve done my best to outline a build that will be future-proof enough to last a good while. I’ll try to clarify some of my choices but I’m very open to suggestions for alternative approaches.
The PC will be for gaming at 1440p ultrawide at over 100fps and I’m pretty sure I want to go with Linux, if it doesn’t cause too many problems. I’m not a linux newbie, but I’m also not an expert. I’ve lived with only linux machines before, and jumped through many a hoop to game on them, but my skills only go so far. If there’s support and drivers for the hardware I want, it won’t cut my performance in half, and I won’t need a degree to understand how to get it to work, I’d really like to abandon windows entirely.
The PC should be able to handle any of the latest games and at least a few years of future releases. I’m not terribly fussy about max settings so long as it plays smoothly and is solid. Stable frames are more important to me than super-ultra shiny settings. Monster Hunter Wilds is the current game I know I wouldn’t be able to play without this upgrade, but I’m sure there will be others. I also tend to multitask a lot, just have a lot of random things running at once, multiple games even, so I’d like have the breathing room to not have to worry about slowdowns from that.
I’m not opposed to overclocking but it’s been many years since I last tried and I’m not looking for something I need to tinker indefinitely. If it can be dialed in during assembly or in the first few days then temps checked every now and then that sounds great, but I’m not looking for something that takes regular upkeep or tuning.
I want a small form factor, and I have a soft-spot for unusual case layouts. My previous build was in an Apevia X-QPack3, weird little black clam-shell thing but I liked it a lot. So when I saw the Lian Li A3 it caught my attention immediately. I’m a huge fan, especially with the tempered glass side, though the O11 compact nearly won me over. If I were to change to a bigger case I’d almost certainly swap to that one.
The rest of the Lian Li internals just seemed to make sense, I like that the Hydroshift cooler keeps the coolant lines out of the view, and I like the way Lian Li’s fans chain together. I’m not sure if the 3 fans in the bottom will fit under the graphics card, or if that even makes much sense to do. I wanted to match the case back fan to the fans that come on the Hydroshift, but I’m not 100% sure it’s right. There is a fanless version of that cooler if I can’t manage to figure it out so I might go that direction.
I chose a Sapphire graphics card because it seemed like they had a good reputation for quality, and the Nitro+ specifically because I really like the way the power connection is hidden away in the back, having the power cables coming up and around to the front of the graphics card has always bothered me. But, I’ve seen the issues with the new 12VHPWR connector and that does scare me. I like having all the power for the graphics card in one cable, especially if the power supply supports it too, but not if it’s going to burn my house down.
I’m not 100% set on the monitor I have listed in the parts, but that’s in the realm of the type of display I’d like to be gaming on. I’ll probably also plug one of my old 1080p monitors in as an extra display, if it’ll fit on my desk.
The rest of the components were either things i saw in other builds that used similar components to what I wanted, or things that just seemed like they’d work.
Let me know what you think, or if I left anything out! Thanks for taking the time to look over my build!
