What does this tell you about my PC and my game? CPU is an AMD 1090t at Stock GPU is a GTX 680 that is overclocked. Sometimes during gameplay the GPU clock will go down to 800mhz for some reason but the temp never goes above 42C
The game can easily get CPU limited on some maps, so that' quite possibly what happens when the GPU clocks goes down. Or simpler than that, if you play with VSync on and the display is happily getting its 60 frames per second(assuming 60Hz display), there's no more work to be done at that moment.
If you're looking to improve performance in some situations, I'd recommend having a try at lowering the settings for Mesh and Terrain quality.
The only real trouble I'm having with the game is texture popping. I've got texture Filtering set to Ultra, but still, sometimes, when I'm driving on a Quad Bike (for arguments sake) tress will just start spawning about 10 feet in front of me.
It's more about the geometry of the trees. Raising Terrain quality and Terrain decoration should help increase the distance for where such things spawn ahead. But performance would suffer for the increased CPU load, more on some maps than others. You'd probably do best to live with it for now.
