So when I first played BF4 during the beta I had great fps, it would venture over 100 fps and never drop below 70. When the game released I was getting about the same, but recently all of a sudden i can't sustain 60 fps.
This first started when one day i started up the game and my fps was much lower than usual (under 60 fps) I restarted the game and then it was okay. These random low fps instances of the game became frequent and now my computer can't sustain over 50 fps at the settings i always used.
The game has been running like this after all the recent patches. I can get over 60 fps if i turn my settings down to medium, but every know and then even at those settings i get low fps.
Aparently dice tested some CF with mantle yesterday and it was geting huge improvements just wait for the 14.1beta driver with mantle its comeing sometime in the next 48hrs.
Oh god, it is really that bad? I'm trying to not play because I have midterms but I was excited for this update and mantle. I was hoping that it would improve the optimizations for my 8350 and 3x290s. Now imjust hoping that the 14.1 mantle update actually does something because I heard that mantle with CF was not the best.
Just started up the game and checked Msi Afterburner and it says i'm using 2.9 GB of vram, this is at medium settings! Could this be the issue and if so how to i fix it.
I have a similar instance where my performance pre-december 20th patch was flawless and i could maintain 60 across the board pretty easily. Then the dec 20th patch came out and i sit in the 45-50 range on maps like seige, zavod, and parcel where before the only problem i had was FPS dropping to the 50's in the middle of zavod. Even aside from mantle they said there were CPU and GPU optimizations in the patch overall but my performance is pretty much the same. Just waiting for mantle now.
I fixed the problem by disabling both Anti-aliasing options (don't know why i had them on in the first place) My fps is fine now but i still get the frame drops that plaque this game. Using high settings over Ultra settings made the frame drops less pronounced.
