Bf3 pc
Hello everyone i was wondering if anyone knew more about pc,s then me but i plan on playing bf3 and i was wondering if anybody could give me a rugh estimate of what i could run bf3 on, like fps and what settings i could maybe run it on etc, and also if there is any parts i should replace for better parts and better perfermance for the same or about the same price, thanks :)  her are the parts /////   http://pcpartpicker.com/p/L2fCgs
uhh any 4 core cpu (not a 4130 i learned the hard way) with a r9 280/5/x
That'll be fine for BF3.  I ran the game on an Intel Core 2 Q9550 OC @ 3.4ghz with 8 gigs of DDR2 and a GTX 470 OC'd 1080p on High settings for multiplayer.  Ultra for the campaign.
What you've listed is better than what I used to have so it'll be fine.
isnt the 6 core better ? i meen i cant afford a heatsink so i dont want to unlock all 4 cores and maybe overheat pc ? but with 6 core 4 are already open ? and also in your mind what is better, This http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
This http://www.amazon.com/AMD-Unlocked-Processor-FD4350FRHKBOX-Black/dp/B00CLBZAWY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1415931251&sr=1-1&keywords=amd+4350
This  http://www.newegg.com/Product/Product.aspx?Item=N82E16819113327
thx and also what one is best if maybe i want to record something ?
http://pcpartpicker.com/p/7yC9yc
I would highly recommend this for bf3 and bf4 @1080p.  Intel cpu and amd gpu for battlefield is the best I think.
I use 8gb RAM ddr3 , Intel i5 3570K, with the Intel 4000 graphics and I get 45-55 FPS with everything on Medium.
From my experience BF3 doesn't seem to make full use of the CPU if you have more than 4 cores.  I have a Xeon E3 and it uses 4 of 8 threads; but if I were you I would go for the FX6300 as a powerful CPU is always important in a strong system.
Your PSU is overkill unless you plan on going for crossfire at some point.  You really don't need a 600W PSU for this system.  Put the money saved into the CPU or GPU or get a 500W 80+ Gold instead.
I used to have a 7950 with i5-3570k on a 450W gold PSU so I think you are definitely overkill on that.  Otherwise everything is great.
That is impossible unless you're on 300x200, source: done it before.
if i overclock anything i would need a 600w though right ?  cause the site says itll use 404 out of 600 so if i get a 500w it might overheat ?
