bf3 help
hey guys thanks for reading,
so i recetly bought bf3 to go with my computer, and every time i attempt tp connect to any server it says that punkbuster.exe has connection problems. I have a stable internet connection and have downloaded punkbuster, anyone know how to fix a prohblem like this?
Make sure Battlefield 3 is in the Punkbuster, if it isn't it, add it then update it. That should work.
tried that didnt work still says disconect I even turned off my anti virus that no work :(
someone help ;~; ive deleted so many programs and tuned my antivirus off is their somthing i misingĀ
have you tried on the battlelog forums.. I know there are alot with this problem right now, im not sure anyone has found a fix yet..
