Better overall performance on two cpu setup
Let the pictures speak for themselves. Which one is better overall performance in the IO throughput and latency on ZFS and peripheral devices? Just asking to skip hours ( days ) of configuration and benchmarking :smile:
Let’s imagine that we have enough cores for both situations.
Setup 1:
Setup 2:
Are you running NVMe drives?
If not, it won’t matter for ZFS.
regarding PCIe layout for the passthrough VMs, as long as you’ve got the VM on the same NUMA node as the physical device, it won’t make a difference. Latency will be introduced when you go across the QPI.
There might be a synthetic difference in performance if you’re running both VMs at the same time, by putting them on different physical packages, but that’s only because of L2/L3 cache evictions. I’m not sure you’ll see any differences in real world workloads.
What about this? Did you mean there is not better handle ZFS pool over QPI with NVMe fast drives? Otherwise you have to split ZFS pool and make two instances.
